Good day! So I noticed a drip in the front lower front end of my jeep. Long story short-gotta crack/leak. See pics below. Any advice on a fix? I’m thinking radiator sealant and epoxy?? Any help is greatly appreciated!!!!
Thanks for the scathing rebuke and psychology lesson. You're obviously butt hurt over my response and seem to be projecting your own issues onto someone that you don't even know. This is a public forum and it was an open question so there was no butting in. Your advice is still bad and you should probably have thicker skin on this forum and stay away from the fix-it-in-a-can aisle at the parts store. Jeep Momma has thicker skin than you do. Instead, consider chiming in with your first hand experience where your proposed solution actually worked.I assume this world-renowned "Expert" KNOWS this person's financial situation (if a guy asks about trying to fix a radiator leak and not replace, it sounds like he's just trying to get by until he can or afford it). I gave options and he barged in with the typical social skills of a neanderthal, and bangs on people. Expected behavior for one from the Bay Area, as I have seen and work with people from that specific area. Not that all are that way. I'm sure he is a hit with all the 20-somethings in the shipping department and they look up to him as a God as he obviously has a self-image problem which most likely stems from his childhood (Dad: "You can't do anything right"). I appreciate this site and the contributions you make and keep it up, Jeep Momma!
I am a very nice person. And super fun!I'm sure Tammy is a nice person. It's just fun to heckle her a little given her past history on this forum.
That could possibly exacerbate the issue. Leaking at the seam between the plastic tank and the aluminum radiator is common on all brands and pre-dates 10-year coolant. Its not the aluminum that goes bad. It's the seal between the aluminum and the plastic from what I have seen.Back to radiator leaks.
I was told that the possible leak issue is due to the change in the coolant. something in the new 10 year coolant which I believe is supposed to be more environmentally friendly is causing some sort of erosion to those aluminum cores. I believe, correct me if I am wrong. (like I need to tell anyone that. LOL!) the leak issue didn't start until the coolant change.
around here, they’re like cold sores.Opinions are like... well, you know 😂
