Post up any new Mod's you've done to the JK!! (WITH PICS IF YOU'VE GOT THEM!!)
New Trektop NX, with and without EVO tire carrier.
/a
Edit: Trying to upload images to tapatalk again.
That top looks great on both Rigs!!!Your image was broken but i love my trektop nx.
someone didnt know that a snatchblock would give double the pull rate so you cant assume anymore when it comes to someones saftey.Yea Im pretty sure we know that.
Sent from Skynet
Nice pics.... wholly they are huge. nice setup with your jeep.... like it :bounce:Trektop NX pics.
Thanksthat the ORH top?? looks awesome
I guess that is angel hair? did you find that it helped?Poly filled the rear speakers
Sent from my iPhone on the toilet.
Your drag link and track bar will no longer be parallel causing sever bump steer. They need to be along the same plane (parallel) and as close to level as possible for best handling.Enlighten me oh wise ones. I just finished welding on a lower track bar bracket (front) . Now there is the stock hole and one that is three inches higher. The instructions say use the upper hole if you have a 'drag link flip'. My questions are why? And what if I use the upper hole without a drag link flip?
edit. BTW my drag link is stock.
The tech writer/company likely didn't want to get into a death wobble/steering handling conversation in their instructions. Doing a drag link flip lessens the angle from frame to axle. Ideally, you want the trackbar and drag link to have the same angles. Raising the axle side of the trackbar gets it back to parallel with the drag link in the majority of builds. (it wouldn't though if you have a frame side trackbar drop mount for example).Enlighten me oh wise ones. I just finished welding on a lower track bar bracket (front) . Now there is the stock hole and one that is three inches higher. The instructions say use the upper hole if you have a 'drag link flip'. My questions are why? And what if I use the upper hole without a drag link flip?
That sums it up!:thumbup:Your drag link and track bar will no longer be parallel causing sever bump steer. They need to be along the same plane (parallel) and as close to level as possible for best handling.
