801 - 820 of 4,188 Posts
Bumpers are painted.
Frame rails are happy.
Hopefully I'll get a few missing pieces for Jeep night show and tell.
Also Jeep will be getting professionally detailed shortly.
With winter coming up a nice coat of wax done by someone who knows that they are doing will be helpful to what little paint i have left.
what bumpers did you go with Charles? i clicked your build thread but it didn't work.
TeraFlex Monster Rear Lower CA's, lengthened about 1/8" over stock. Reprogrammed computer for my tires (shifting MUCH better now).
Still have an elusive rattle - sounds like a loose muffler (but it isn't). Also have (what sounds like) 2-3 very squeaky shocks (Bilstein 5100's). Will investigate the noises this weekend.
The rattle is probably the welds on the crossover..there's a writeup I'll tryin find it...once I did it mine became silent..,
Edit: here try this http://www.jkowners.com/forum/showthread.php?t=48751
Just looked real quick - the heat shield is still firmly attached to the pipe, but the pipe is making contact with my skid plate. They actually make a spacer for my skid (if I remember correctly) to provide a little more clearance there.. Will test to verify that's what it is and go from there..
Replaced driver side axle shaft - stupid c-clip...
Installed Tuffy glove box to try and keep those thieving degenerates at bay...
Pic doesn't show it but color is spot on and there is actually a bit more storage room than stock.
Mounted a Kargo Master rack to the roll bar. I wanted something that just mounted to the roll bar for extra gear for camping and what not. Can't use the soft top or hard top with this set up as that's not want I wanted. Just wanted a set up only for roll bar mounting. It was mounted in two places. I used the original holes in the roll bar for the soft top frame and use a u-bolt for overkill. It is mounted as you can see with a wing nut but that was replaced with a nylon washer.
This could go in the vent section as well
For some damn reason my Rock Krawler shocks, which I love by the way, are rubbing on the frame rail. Also my damn driver coil spring was rubbing on the power steering pump bolt which is attached to my poly upper track bar relocation bracket. My springs were bowed in so I reversed my springs and grinded down the frame rail. Hopefully this workers better.
This is where the shock is rubbing so I grinded it down. If you remember I did this as a quick fix on the Rubicon Trail but needed to make it better.
The next two pics is where the coil spring was rubbing the power steering pump bolt. Damn near rubbed 1/4 of the ****** off.
Here is the damage to the shock housing. Just scrapped up really as there is no structural damage.
You need these. Tell the wife it is a safety issue!
http://www.polyperformance.com/shop...om/shop/Synergy-Suspension-Jeep-JK-Front-Lower-Shock-Mount-Bracket-p-17962.html
:beer:
You need to tune in your front end better.. If your having all those rubbing issues the axle might be to far forward
