I just got done installing a Teraflex 2.5" coil lift with 1/2" rear guide spacer, Teraflex front/rear monster trackbars and lower control arms, bilstein 5100's and spidertax wheel spacers.
It was not that bad but I ran into a couple of problems.
1.the weld on my trackbar relocation bracket snapped off when I went to torque it down. I went ahead with the install using just the adjustable rear trackbar.
2. could not get the rear upper control arms in for the life of me even at the minimum length the pinion angle seems steep but others are getting away with it so I used the factory bars. Also I noted on the Teraflex instructions there is a note that states it is highly recommended to use the factory bars with a 2 door.
3. I set the front lowers to the recommended lengths 23 1/8 driver and passenger 23 1/4" When I took it for a ride I had some bad vibrations. I set them to 22 3/4 and the vibration went away and my caster is at 4.2 / 4.4 and rides nice.
Should I get and install a new trackbar bracket or is the adjustable enough?
Should I install the rear uppers and align my pinion angle? If I do that I think it would be wise to get some correction wedges to take the bow out of the springs I will incur.
Otherwise rides pretty darn good!
