Has anyone used this kit yet? I am interested to here what the quality is like regarding the cast aluminum reflector and mounting brackets that hold the Hella Bi-Xenon projector. I assume the reason this turnkey kit is DOT approved is because they did not retrofit a projector inside a traditional headlamp housing. The look is definitely unique and I am not sure if I like it or not but it seems to be the most pure example of a turnkey Bi-Xenon kit for the JK. I am also considering the HIDprojectors.com turnkey solution.
Susquehanna 90mm Hella Bi-Xenon Kit
http://www.rallylights.com/detail.aspx?ID=5178
90mm Bi-Xenon Headlamp Kit for Replacement of 7" Sealed Beam.
• Cast Amuminum Reflector.
• Hardened Glass Lens.
• D2S Capsule.
• Plug and Play Installation
• Solenoid Operated Shutter Creates Low Beam Cutoff and lifts for high beam
• Shutter defaults to Low Beam Position.
• Trim Ring Available in Chrome or Paintable Black
• Used in motor coaches and buses where cost is no object.
• Used in competition cars from Rally to endurance prototypes
• Used in many custom and super cars
• Exclusively from Susquehanna Motorsports
SM6024BXB Kit for ONE H4 Headlamp Includes:
• 1-DOT Right Hand Drive Headlamp
• 1-Custom SMS Mounting Bracket
• 1-Custom Paintable Matt Black ABS Trim Ring
• 1-Hi/Lo Sealed Beam to Bi-Xenon Transition Harness
$640.30
SM6023BXB2 Kit for TWO H4 Headlamps Includes:
• 2-DOT Right Hand Drive Headlamps
• 2-Custom SMS Mounting Brackets
• 2-Custom SMS Paintable Matt Black ABS Trim Rings
• 1-Hi/Lo Sealed Beam to Bi-Xenon Relayed Transition Harness for two lamps
$1387.10
• D2S Capsule.
$640.30
$1387.10
