High-speed wheeling without coilovers and long arms
14K views 62 replies 26 participants last post by  Ryanralston07
#1 · (Edited)
I know this will prompt a lot of "save up and do it the right way!" discussions but I'm throwing this out there anyway.
What I'm trying to do is get a short-arm Jeep to ride average to above-average on whoops, broken terrain and sand dunes. Thinking 40-50 mph on washboard/broken ground without bottoming out or getting too much air time with each tire.
What would you need to do to a short-armed Jeep to allow it to run somewhat well on those kinds of terrain?
I run a cheapo Rough Country 3.5 Series 2 suspension kit and while it has done very well on slow stuff, it's just bearable on-road and downright dismal on the dunes. My visit to Silver Lake in Michigan exposed all the flaws it had - I bottomed out hard on most landings and even while on approach to a dune and hitting ruts along thw way. Once my axles bounced and my wheels started to unload I lost traction and power and couldn't make it up the higher hills. Granted, I have several hundreds of pounds in aftermarket parts on, but I didn't think I'd do as marginally as I did.
I have some feedback from my buddies already: progressive coils, better shocks, possibly bumpstops. I wasn't sure if the AEV geometory correcton brackets would help since they flatten out the front arms - seems like they would.
If anyone is running a fairly good high-speed short-arm setup, can you chime in with your personal experiences? Thanks much!
#6 ·
Big difference between progressive vs linear coils for washboard stuff? Or no difference?
#10 · (Edited)
Cool. So far that's what I'm concluding too.
Right now it's:
Synergy progressive springs - 3 inch
http://www.quadratec.com/products/16315_8000.htm
http://www.quadratec.com/products/16315_8002.htm
Blistein 5160 shocks with reservoirs
http://www.bilsteinus.com/products/...om/products/lifted-truck-off-road/5160-series-stock-mount-remote-reservoir.html
ProFender air bumps
http://www.profender4x4.com/products/bumpstop3-4.php
Good bit of coin but still a far cry from coilover and long arms. Thanks for the input!
Now one last question:
AEV Geometry Correction Brackets...
http://www.quadratec.com/products/16502_4301.htm
Worth putting in or a waste of time for high speed/stability stuff?
#11 ·
I do very well on fast washboard roads and dunes with my short arm set up. I have the Rock Krawler 2.5 MaxTravel with RRD w/ remotes. Teraflex speed bumps, 35 inch Trail Grapplers, Poison Spyder flat flares and sleeved/ trussed/ gusseted front axle.
#12 · (Edited)
I have Bilstein 5160s. They tend to be on the stiffer side which is what I wanted in order to maintain really good on road manners. For fast offroading, you may want to look at some other options.
I know RK will custom valve a set for you and I have been hearing really good things about the Kings (but they are ridiculously expensive)\
Ask 2k2WranglerX about AEv :)
#13 ·
So you want a race jeep huh? on the cheap???? My old Tacoma had go fast suspension, and the truck fell apart around it after a year. (Read that sentence again...) Then I saved up and built my (now sold) 1994 Toyota truck the right way. Full cage, King C/O with bypasses and air bumps. It could do 50-60 in the whoops. Maybe faster, but that little 22re could only push it so fast.
I want my current jeep to do the same, but there is no way in hell a straight axle is gonna do 50 in the whoops without some KOH cash. Sorry Rancho, but your shock ain't gonna do it. WAJ... I spent a lot of time doing suspension tuning with slo-mo video, changing valve stacks and, and fluid weights to finally get the truck to ride smooth in whoops.
Your best bet is to soften the big hits out with either a bypass shock or high quality bump stops. Probably both. I even question how fast (and how long) you can drive a jeep with the double throwdown kit from Evo.
Just get the coils, a good shock, and bumps and enjoy the whoops at 25-30 mph.
#14 ·
Bypass is def another very good way to go but def ups the price a good deal because you also have to get some sort of upper mounting bracketry in there to make it happen.
I know Paul from Nemesis has that type of setup on his 2 door and it looks bad ass. Sadly, I havent had a ride in it :bawling:
#17 · (Edited)
I was reading somewhere that with lower ride heights ... say 3", the long arm really isn't that much of a benefit due to clearance issues.
I wonder how valid that statement is since I happen to have a 3.5" full short arm kit and very strong desire to not delete the exhaust loop on my 12 JKU (said to be almost a requirement to go long arm).
Since I do some light crawling (often with the OP), I value decent flex and I think I have it pretty good with my current kit (see my sig).
But I also run burmed logging roads and would like to find a solution that will let me throttle through a bit more.
Forgive my typos. I'm too lazy to proof read on a tiny iPhone screen :)
#22 ·
ProFender is import? Ok that changes things...
#25 ·
Teraflex Speedbumps: $931 for a full set
ProFender: $139 per air bump, $26 per mounting can. Dunno if there's a rear version or not.
Kinda iffy on ProFender the more I think about it. Teraflex may be a more complete package and a cleaner install. Then there are the Fox air bumps too... Decisions decisions.
#26 · (Edited)
My $.02:
TF's from Quadratec for $875 - I'm sure you can get free shipping through some forum discount dileo. :)
$556= ($139*4) + another $104= ($26*4) in cans for mounting = $660
So another $215 to not have to hack your frame up and deal with welding?
If you're not going to do all the cutting and welding of doing coilovers, then why not?
Another thing: The TFs are made specifically for the JK (save variance between 2/4 door weight) in form and fit while the ProFenders seem to be universal.
Fox = same situation but more expensive.
Yea...decisions decisions ;)
#30 ·
I think Teraflex is the only product that offers ease of installation. Not that I don't like to work on my Jeep. I worked on everything on it minus re-gear , sleeves/gussets and installing my rear TrueTrac... but with a life to get back to, the TF offering is almost worth the price of my time. Leaning heavily towards TF compared to generic cans. Plus, I don't see any of them offering rear air bumps. TF does.
#31 · (Edited)
First off stop comparing TF speed bumps to other bump stops , TF is foam just like what you got now and the day stars
Me even it was a little bit of a headache to install I would go with fox , king or something in the air or oil family and the plus to that is you can find them used cheap as crap ( go on pirate )
At the end of the day it is your money 1000 for foam or 1000 for oil or air
#40 ·
Look at it from a usage stand point. Baja race teams arent limited by budgets and only go with the best in order to survive something like a Baja 1000. Have you seen alot of those teams use foam bump stops?
Going with something like a King bump stop also allows for adjustability as you can change the nitrogen pressure and it has a longer stroke.
Did you know that the Savvy KOH rig that won last years every man race used TeraFlex SpeedBumps?
You do not have to remove the exhaust hoop with a TeraFlex Long Arm kit. I would stick with a short arm with that height unless you really want to spend the money for a long. A 3" short arm SpeedBump/FOX combo works great IMO for most offroading situations.
#46 ·
Do you have/can you shoot any pics of where the driver-side control arm mounts in relation to that hoop? Much appreciated if you do. :)
The Fox/Speedbump app is now on my Xmas list :)
Forgive my typos. I'm too lazy to proof read on this tiny iPhone screen :)
#38 ·
For front bump stops you can get the Evo mount cans. They are pricey for what they are but they do not require welding. You will have to weld a bump can in for the rears, the Teraflex rear bolt on bumps seem to be useless, I believe their prerunner kits now come with a weld in rear.
Im setting my jeep up very similar Teraflex 2.5 with arms and Bilstein 5160s but havnt done the bumpstops yet. The jeep performs good now through washboard and rough desert up to 50-60mph just hits hard with regular bumpstops.
The Bilstein 5160s perform great at speed and have a shorter body then similar Fox or Kings allowing you to get more uptravel.
#41 ·
Just because I have personal experience with this environment and our Game Changer suspension, I thought I would throw this in.
In Ocotillo Wells, going through the washes with whoops, washboards, etc, our Cloak'd JK (stock engine, Game Changer suspension, MC steel body armor) was running upwards of 70mph.
This was early in 2012 at Tierra Del Sol Desert Safari and one of the first times I had personally pushed our new suspension in that environment. One of our friends in a Hemi'd JK and I decided to race the washes. I won't mention the suspension he had, but we took off, and I watched the speedometer as it climbed from 45-55-65... and the ride was incredibly smooth. I was personally shocked by what our bolt-on high-misalignment rock-crawling suspension was capable of in a pre-runner environment.
Oh... and the Hemi'd JK... couldn't go more then 35 in the same stretch. The suspension just couldn't handle it.
There are lots of great companies mentioned on this thread, but the Metalcloak 3.5" Game-Changer Suspension, as a bolt-on kit with total install time of about 6 hours, truly has set some new standards on what a bolt-on, short arm kit, can do.
#42 ·
Thanks for that input! I haven't researched metal cloak at all but this prompts me to give them a serious look!
#49 ·
Another thing to consider with bump can style bump stops is. Where do you plan to mount them with all the oem mounts in the way? I might be wrong here but I don't recall seeing or reading anyone with bump can style stops with the factory spring shock set up.
Teraflex has that market with there speed bumps. Easy of install and perfect for the jk. They are expensive I totally agree with that. But for some applications like the op mentioned these are ideal. Imo
Sent from my PG86100 using Tapatalk 2
#50 ·
I'm sold on TF speedbumps too. Now I just got to go sell my right kidney to buy them. Oh well, I hope Santa Claus still exists...
