Poison Spyder & Fox Hydraulic Bump Stops - JKowners.com : Jeep Wrangler JK Forum
Old 07-16-2011, 12:11 AM   #1
JK07
Member # 4312
My turn just finished installing Poison Spyder Brawler Lite Bar customized to fit Warn M8274 High Mount Winch & also installled custom work Fox 2.0 Hydraulic bump stops
JK07 is online now   Reply With Quote Quick reply to this message
Old 07-16-2011, 07:32 AM   #2
fourplyn
fourplyn's Avatar
Member # 5388
Sweet set up...luv it.
Is it just me or is your jeep leaning to the left just slightly? Driveway maybe?
__________________
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 10:02 AM   #3
DTJK
DTJK's Avatar
Member # 7175
I'd like to take a closer look at your light bar and mount.
DTJK is offline   Reply With Quote Quick reply to this message
Old 11-01-2011, 02:48 PM   #4
GRIZZLY47
GRIZZLY47's Avatar
Member # 12618
Feedback: 13 reviews
Can I ask how much you paid for your Bump stops? Im researching the Pros/Cons of doing Hydraulic bump stops vs non Hydraulic.
__________________
2010 4-DOOR MOUNTAIN
GRIZZLY47 is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 09:55 AM   #5
highwayman
highwayman's Avatar
Member # 13395
Not alot of cons to hydro's as far as function. Unless cost is the factor. Been running em on the frt & definately doing rears soon.
highwayman is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 10:23 AM   #6
pnut
Member # 247
I am looking at the Teraflex speedbumps, they do look like a good alternative. unaffected by temperature, progressive rate, less moving parts, don't need a charge, etc. Still not 100% sold yet though.
I will be interested to hear over time how you like the hydros.
__________________
07 Rubicon Unlimited - Teraflex 3" prerunner lift, 35's, 5.7 Hemi using AEV kit, Teraflex CRD60 rear with 5:13 gears all around.
pnut is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 07:24 PM   #7
GRIZZLY47
GRIZZLY47's Avatar
Member # 12618
This may be dumb, forgive me, can you explain the difference of the teraflex speedbumps over one that needs a charge? what charge does it need?
__________________
Old 11-02-2011, 09:03 PM   #8
yerfttam
Member # 17032
Ahhh....always good to see an 8274. Lookin good!
__________________
2010 Rescue Green JKUR
-37 Pit Bulls / Raceline beadlocks
-RJ60 rear / 5.38's / Detroit
-Rubi 44 front / sleeved and trussed / RCV's
-PSC hydro assist / Synergy TR & Drag Link
yerfttam is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 02:39 AM   #9
ibjammin
ibjammin's Avatar
Member # 8660
Air bumps use nitrogen gas as the spring and you can adjust the pressure to make them soft or hard and some may leak a little over time and need to be recharged where the TF bumps use a composite material as the spring to slow down the axle as it bottoms out...
http://www.teraflex.biz/news/terafle...ump-bumpstops/
ibjammin is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 09:48 AM   #10
highwayman
highwayman's Avatar
Member # 13395
I love em. Not really sold on the stinger design. If your going to step up, Id go with Hydro's. Id rather stick w/Hydro's. Especially the rear, not a big fan of two collapsible bumpstops for a bumpstop.
Old 11-03-2011, 10:03 AM   #11
GRIZZLY47
GRIZZLY47's Avatar
Member # 12618
But I would have to keep recharging the nitros?
__________________
Old 11-03-2011, 10:18 AM   #12
highwayman
highwayman's Avatar
Member # 13395
Theyre like everything, if not maintained theyll leak. Otherwise they dont need constant recharging. You will need to go w/a quality gauge set-up for checking PSI. KarTek sells a great one. All kinds of stuff can leak, shocks, tires, etc, I definately wouldnt let charging be an issue of not going w/Hydros. They rarely should need charging, unless something is worn.
Old 11-03-2011, 11:03 AM   #13
GRIZZLY47
GRIZZLY47's Avatar
Member # 12618
Hmm Ill have to read more into this, Hydros* not nitros dont know why I put that. What models have you guys tested? I know Fox and King make hydros but idk who else
__________________
Old 11-03-2011, 05:28 PM   #14
drulg
drulg's Avatar
Member # 3069
What kind of tires are those?
drulg is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 07:22 PM   #15
highwayman
highwayman's Avatar
Member # 13395
Im running JKS ACOS PRO in the frt. Ill probably get the mount plate from EVO & keep scouring classifieds for bumps in the back.
Old 11-04-2011, 05:59 AM   #16
JK07
Member # 4312
There is no match for hydraulic bump stops imho. No you do not need to recharge them on regular basis i have been running them for almost a year with no gas leak or anything same as my king shocks nitro filled
I dont do rock crawling so hydro bump stops are essential for my kind of trials and driving.
Teraflex are not hydro bump stops they are just another foam filled bumpstops and i dont see any reason conpared to stock.
You need a custom job to install hydros in front and rear and cutting and welding is reqd also you have to loose or cut modify the windscreen washer bottle to clear the bump stop on left side
The tyres are Maxxis Trepadors 37."
Old 11-04-2011, 06:54 AM   #17
ibjammin
ibjammin's Avatar
Member # 8660
Teraflex are not hydro bump stops they are just another foam filled bump stops and i don't see any reason compared to stock.????
http://www.youtube.com/user/teraflex...?blend=19&ob=5
There is a difference in the stock and TF bumps watch the vid! yes hydro's are better but some don't want to hack up the frame to install the rear bump cans so the only other options are the TF and JKS bumps the problem with the JKS set up is you add 1.5 in of lift in the front and i think it was 2 in of lift in the rear so to keep the same amount of lift you will have to go to a shorter spring to compensate for the difference?
Old 11-04-2011, 07:07 AM   #18
ibjammin
ibjammin's Avatar
Member # 8660
Hey how do you like the King 2.5's are they good out of the box as far as valving goes? I have a full set of the 2.5's Kings with adjusters on the way for my build cant wait to get them!!!!
Old 11-04-2011, 04:49 PM   #19
JK07
Member # 4312
Love the kings. The king valving is just perfect a very good balance.
Old 11-04-2011, 04:56 PM   #20
Mr.RonGilbert
Mr.RonGilbert's Avatar
Member # 3399
Sweet setup for sure!
Mr.RonGilbert is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
