Finally my build thread 3.5" RK Lift w/ 40's.. - JKowners.com : Jeep Wrangler JK Forum
Old 08-29-2010, 03:51 PM   #1
fourplyn
fourplyn's Avatar
Member # 5388
fourplyn's Build.
I'll post more later... and do a full write up. But for now here is what I have.
07 Jeep Wrangler Rubicon 4 dr
Stock D44 axles
5.38 gears - 4 Wheel Parts. G2 gears
Front:
Fenders, Poison Spyder Customs Aluminum flat fenders - regular width
Truss - Rock Krawler
C- Gusset's upper/lower (Powder Coated black)- Poly Performance
Inner sleeved - Poly Performance
Red Neck Ram Hydro Assist Steering
PSC 1600psi Pump , smaller pulley
PSC Filtered Reservoir - installing
Tie Rod Clamp 1.75" - Poly Performance
Tie Rod Pro Alum. - Rock Krawler
Diff. covers - ARB
3.5" Rock Krawler Coil Over lift
Rock Krawler 11" (2 5/8") Coil Overs w/ remote Reservors. Aluminum bodied
Track Bars Adjustable, Pro Aluminum. - Rock Krawler
Drag Link (Steel) Pro series - Rock Krawler
Ultimate Steering upgrade flip kit pro aluminum. - Rock Krawler
Extended Stainless Steel brake lines - Rock Krawler
Upper/Lower Coil-Over mounts (powder coated black) raised 2" - Rock Krawler
Upper Shock Mount small brackets - Gen Right
Stock Ball Joint's drilled w/ Zirk Fittings on top, stock on bottom - Mopar
40" x 18" Pro Comp X-Terrain's Tires
18" Spyder Locks Powder coated blue, rings modified
Front bumper BFH - Poison Spyder w/ D-ring mounts
3 link Adj. Pro Aluminum Long Arms- Rock Krawler
Tie Rod, Pro Aluminum - Rock Krawler
Rear:
3.5" Coil's - Rock Krawler
Adjustable Spring pad's - Ruffstuff Specialties
Track Bar Adjustable, Pro Aluminum - Rock Krawler
Extended brake lines stainless steel - Rock Krawler
Bilstein 5100 Shocks, A.E.V. tuned
Lower Shock mount's 2" higher than stock - Rock Krawler
Rear Bumper BFH with D-ring mounts - Poison Spyder
Rear Tramp Stamp - Poison Spyder
Rear 3 link Pro Aluminum Long Arms - Rock Krawler
Interior/Exterior:
Front "Rubicon" MasterCraft bucket seats - Drivers & Passenger w/ map pockets and custom colors
Soft Top "Fastback", Custom color gray - Offroad Heroes
Hood wrangler hood straps - Daystar
Air Filter - K&N
Larger main pulley on engine - PSC, so stock belt can still be used
Evaporator cannister Cover - Poison Spyder
Rad Valves on wheels - Rad Valves
Drive Shaft's front/rear - Tannon Drivelines
drivers/passenger/rear cargo area - Husky Liners
Black Billet gear shifter knob - Drake Offroad
__________________
- 40" Pro Comp X-Terrain
http://www.jkowners.com/forum/showthread.php?t=35749
fourplyn is online now   Reply With Quote
Old 08-29-2010, 04:34 PM   #2
johnnyboy110
Member # 5739
Man, that is sweet. I've got the 3.5 Rock Krawler entry level kit and 35"s and knew that a bigger tire would fit.. Looks good man
johnnyboy110 is offline   Reply With Quote
Old 08-29-2010, 04:41 PM   #3
block
block's Avatar
Member # 6132
looks sweet ! nice job man.. i bet your happy to finally get it put together shocks look great... i see the sliders worked out . nice job
block is online now   Reply With Quote
Old 08-29-2010, 05:09 PM   #4
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
You powdercoated your lug nuts!?
Co4Lo is offline   Reply With Quote
Old 08-29-2010, 06:06 PM   #5
SlvrJK
SlvrJK's Avatar
Member # 8383
Looks good, I like the attention to detail you put into this build so far.
__________________
2008 JK X 2-door, 37" MTRK's, Xenon narrows, 2" Frankenlift, Prorock 44 front with 5.13's/rcv's/rubi locker, Rock Jock 60 rear w/ 5.13's and a Detroit, and lots of armor...
SlvrJK is offline   Reply With Quote
Old 08-29-2010, 06:10 PM   #6
Mr.RonGilbert
Mr.RonGilbert's Avatar
Member # 3399
Nice!
Mr.RonGilbert is offline   Reply With Quote
Old 08-29-2010, 06:26 PM   #7
RODICON
30 Years of Rockin!
RODICON's Avatar
Member # 2233
Sweet set up!
__________________
2010 Rubicon 2 door, Synergy 5.5" stage 3 lift with fox 2.0 shocks,38"Km2/ Trail ready hd beadlock wheels,Poison spyder evap skid, diff covers,crusher corners,fenders/Rocker knockers ,Warn 10k winch with Hanson front and rear bumpers and rack,Viair 480c air system, Superchip tuner,Mopar CAI,Rotopax, tub enlargement,Tera44,2low, PSC steering, 5.13 gears,chromoly axle shafts,Woods driveshafts,CB, Arb fridge and AA t case cable.
RODICON is offline   Reply With Quote
Old 08-29-2010, 06:36 PM   #8
planman
planman's Avatar
Member # 3083
Looking good.
planman is offline   Reply With Quote
Old 08-29-2010, 08:07 PM   #9
wsoffroad
wsoffroad's Avatar
Member # 10770
Feedback: 12 reviews
Looks good man loving the powder coating!
__________________
Rock Krawler, Poison Spyder, Rigid Industries, Currie and more.
WWW.WSOFFROAD.COM OR CALL 813.361.0869
Like Us on Facebook for FREE stuff!
wsoffroad is offline   Reply With Quote
Old 08-29-2010, 09:16 PM   #10
fourplyn
fourplyn's Avatar
Member # 5388
Lol, yeah. He only charge me like 10 bucks to do them...So I figured, what the hell. I didn't want chrome..
I finally drove it today..WOW...amazing ride. Just went to the Bronco's game..and must have turned every head in the parking lot..
The 5.38 gears make a huge difference..I have the same pickup as if I had a stock rig. I'm more than happy with the set up. I'm just happy its finally on. I was getting tired of waiting on everything to be powder coated and installed.
__________________
Old 08-29-2010, 09:21 PM   #11
TONKAJEEP
Member # 9841
Hey man...that thing looks awesome!
TONKAJEEP is offline   Reply With Quote
Old 08-29-2010, 09:28 PM   #12
TEXASKEV
Member # 112
Nice build man. Gotta love that RK stuff.
__________________
My RK Long Arm Coilover Build Pics
Rock Krawler Suspensions
TEXASKEV is offline   Reply With Quote
Old 08-29-2010, 09:31 PM   #13
PIG
PIG's Avatar
Member # 119
Build looks good... I think a set of THESE would be pretty rad for your build.
__________________
Click the sig for everything you need to build a JK... 805-783-2060
NEW PRODUCTS ADDED DAILY !!!
www.SynergySuspension.com ----> Click and download the new catalog!!!
PIG is offline   Reply With Quote
Old 08-29-2010, 09:34 PM   #14
fourplyn
fourplyn's Avatar
Member # 5388
I like em...I'm so scared to grab the ones I got. Last ones I had, I ripped em right off the first time. I'll stew on these and probably give ya a call when I get back from my trip.
__________________
Old 08-29-2010, 09:36 PM   #15
andrelopez99
andrelopez99's Avatar
Member # 5329
NICE!
__________________
andrelopez99 is offline   Reply With Quote
Old 08-30-2010, 03:26 AM   #16
militaryman4455
militaryman4455's Avatar
Member # 8813
Thats one of the cleanest rigs I have seen yet... Your color scheme is perfect and you're running 40's on a fairly low rig :thumbsup: But I have to ask what the Ramicon is? Its cool, but maybe I missed something about your build... Do you have a hemi
__________________
2010 JK Sport
Mod..Wheel..Break..Repeat
MARYLAND JEEPS/ELEMENT OFFROAD
Criminals prefer unarmed victims:Μολὼν λαβέ
Originally Posted by cjcraig7 View Post
I think I understand your question - but I am a two door guy.
militaryman4455 is offline   Reply With Quote
Old 08-30-2010, 05:50 AM   #17
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
That really did turn out nice Troy! When do you want to go test it?
Old 08-30-2010, 06:13 AM   #18
fourplyn
fourplyn's Avatar
Member # 5388
Ramicon - well it started with RAM which is the emblem I replaced on the front grille. Ram goes back to my college days..my best friend in Alaska and I would say Ram every time a hot chick went by or as a tention breaker...or when we'd leave a message on the phone, or when we'd meet.. Corny...but its stuck with me for ever...even my folks say it to me all the time..
Hemi....well, when I pay this thing off...then I'll think about puttin the Viper engine with a super charger in it. I'm not getting rid of this thing....EVER.. So plans for the future are wide open. This will go through a lot of changes..
Thanks. As soon as I fully break these gears in and get this Hydro steering fixed. Hopefully while I'm gone this week. Plus I need to install bump stops lol...
__________________
Old 08-30-2010, 06:20 AM   #19
militaryman4455
Member # 8813
Oh ok, gotcha... Was thinking it was refering to the Dodge Ram... It does look good with that emblem though
__________________
2010 JK Sport
Old 08-30-2010, 07:17 AM   #20
ALASHA
F5 Champ
ALASHA's Avatar
Member # 6694
Very nicely done Troy.
ALASHA is online now   Reply With Quote
Old 08-30-2010, 07:23 AM   #21
planman
planman's Avatar
Member # 3083
With a 1" body lift, I needed 3.25" front and rear extended bumpstops.
Without a body lift, maybe start by trying 4" extended bumpstops front and rear and see how much you are willing to trim.
In addition to extended bumpstops, I had to do a little trimming (although the Poly sliders required no trimming):
Old 08-30-2010, 07:32 AM   #22
fourplyn
fourplyn's Avatar
Member # 5388
Plan...you should see how much I trimmed off..I got lots of clearance..lol..I'll have even more when I install Adj. RK Arm's.
Heres the front of the rear fender well...that I trimmed. I took off about 3"
__________________
Old 08-30-2010, 07:35 AM   #23
ALASHA
F5 Champ
ALASHA's Avatar
Member # 6694
Troy, you have any close ups of the coilover mounting brackets?
Old 08-30-2010, 07:39 AM   #24
PUDDLZ
PUDDLZ's Avatar
Member # 833
Ride looks nice
PUDDLZ is offline   Reply With Quote
Old 08-30-2010, 07:52 AM   #25
Obstruction of Justice
Obstruction of Justice's Avatar
Member # 6064
I wanna see pics when you put that BFH rear on! Your ride looks sic!
X2 on the mounting bracket pics for the coilovers!
Obstruction of Justice is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
