1 - 13 of 13 Posts
WTB: JK Dana 44 Front Axle. Prefer it to be complete, brakes and all, but will consider others.
I live in virginia beach virginia and may be interested. let me know.
In about 4 weeks I will have a complete D44 hp for a JK (or other, since its built to order but getting the outer stuff for a JK in about 4 wks).
It would be:
Ford High Pinion D44 that is built by Currie:
*New Thick wall and large OD tubes (dont have to worry about sleeving them)
*JK inner C's with lower Gussets
*JK Specific Thick HD Currie brackets with JJ upper ends for better articulation
*Any Ratio you Disire Quality gear set
*New differential bearings
*New Spartan auto locker
*New inner seals
*New ball joints
*New Inner Currie extreme axles
*New Mopar JKD44 Ujoints
*New Ten Factory Outer Axles
*Stock JK outer knuckles, brakes, unit bearings, and calipers.
Total $2840 plus shipping of about $175-200
Let me know if your interested. This is by far a better axle then the JK D44 front. I can add in a air locker or electric locker if wanted.
Robert
To be honest, I would like to buy just the housing if possible because I am building it for a TJ. Let me know what we can do.
If its for a tj buy a ford 44 high pinion. Its cheaper and only 3/4 of an inch longer.
Sent from my DROIDX using Tapatalk
Actually closer to 3+" per side wider and the pumpkin is pushed over to the side too far typically unless u shorten one side and then you might as well just have the right axle built with the right parts, the first time. IMO
levellinebrad, do you still have that d44 front axle for sale?
1 - 13 of 13 Posts
