Not much to it, but I thought I'd throw a few pics on here to show how easy it is to install. It literally only took 15 minutes from start to finish.
Tools needed:
3/8" drive ratchet
19mm socket
13mm socket
19mm wrench
1/2"-20 tap
tap handle
tapping oil
The tap is available for purchase from Woods, but I already had one lying around. Here's the link to the product itself:
http://jeepswag.com/jackmount/index.html
Step 1: uncover the holes to be tapped. I was happy that I only needed to undo the rear corners of my Bestop Safari Bikini to get to them:
Step 2: Remove the 13mm bolts from the sport cage, and tap the existing bungs 1/2"-20:
Step 3: Loosely install the brackets with the supplied hardware, and reinstall the factory 13mm bolts.
Step 4: Bolt the Hi-Lift to the brackets with the supplied bolts.
Final Step: Finish tightening the bracket bolts to the sport cage.
That's it...Done.
SUPER easy install and gets the jack out of the way. I didn't want it mounted to the rear bumper (couldn't mount it to the BFH anyway), and I'm not a big fan of hood-mounted jacks either. I keep thinking I'd drop the heavy bastard on the hood...
Very happy with the product!
-WRM
Tools needed:
3/8" drive ratchet
19mm socket
13mm socket
19mm wrench
1/2"-20 tap
tap handle
tapping oil
That's it...Done.
-WRM
