1 - 2 of 2 Posts
2017, rhino JKU Rubi Recon
So i need a constant and ignition wire... I am prolly gonna run the constant power thru thr firewall straight to the battery where is a good place to get ignition on power? Cigarette lighter? How do i get to it?
**edited** the picture was worded wrong
I am assuming that you have an aftermarket head unit. The way that I have always done this is with a 12 volt relay and a power distribution block.
http://www.radioshack.com/product/index.jsp?productId=3020762
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=5&series_id=39&family_id=73&item_id=108319&locale=en_US&p_status=
you can also put a toggle switch on the remote wire so that the amp can be turned of if you are being hassled by the "man."http://www.jkowners.com/forum/images/smilies/thefinger.gif
hope that helps
1 - 2 of 2 Posts
