I am planning on using a Daystar lower dash switch panel.
Could someone give a an idea or even if they have a picture or 2, the best and easiest way to get wires from panel through firewall and into engine compartment to connect to relays?
Gunnery Sergeant USMC (ret)
On each side of the jeep behind the side dash panels there is a hole with foam in it. Just take a metal coat hangar or fish tape and run it through there and into the engine compartment and then pull your wires through.
Use a skewer and a little duct tape to hold the wire, and pull through. I widened the hole with the skewer and the wrapped a little tape around the skewer and the Loom. As you pull with one hand on one end, guide it carefully The loom slid through nice and smooth on the other end. 6 wires at once. It's the big red and black loom on the right
