I cannot for the life of me get the panel off the door to replace the window regulator. Does anyone know of the 3 screws around the locking mechanism have to be removed in order for the panel to be taken off?
I can’t find an food YouTube videos, all of the ones I have seen it just came right off after removing all the bolts.
If I remember correctly, I think you’ll have to lift the glass pane up and secure it before removing the inner door panel. Otherwise, if you rotate the panel toward the front of the Jeep before pulling out, that vertical bar should clear the door and then allow removal. It took me a minute to figure it out, but it does come out without disconnecting the vertical bar.
My issue is that I have some kind of clunk inside the door, but when I open it up there’s nothing loose so I’m currently stuck on what to do next.
