1 - 1 of 1 Posts
Front Shorty-style bumper with Plow
-Made from 1/4" steel
-Built-in Winch Plate
-Built-in Snow-Plow mount
-Factory Fog-Light mounts
-Front Stinger Bar (I can add spotlight brackets if you want, or take it off if you don't like the look)
-Comes with 6-1/2ft Meyer SnowPlow!
- $600
Plow mount uses a custom quick-disconnect. The plow mount bracket goes on/off in just a few minutes, and you don't loose any ground clearance. Uses your winch to raise/lower the plow.
Heavy Duty Roof Rack
- Made from 1-3/4" .120/.095 wall tube
- Will hold a couple hundred pounds easily
- Front mounts to windshield bracket, rear attaches to frame
- Has fog light mounts
- Made for 4-door
- $400
Mile Marker 10,500 Hydraulic Winch
- Comes with remote & hydrauilc solenoids
- Power Steering connectors/hoses for JK Wrangler
- $700
Will make a deal on the full setup.
Call/text anytime, 719-357-7045
Thanks.
-Tim
1 - 1 of 1 Posts
