1 - 15 of 15 Posts
I have found what looks like a good deal. My only issues is will they fit. I have installed the leveling kit with spacers front and back. The kit it measured 2" in the front and 1" in the rear. I measured 1.25 all around. Will these tires fit on stock rubicon wheels and my set up?
Thanks in Advance.
http://louisville.craigslist.org/pts/2826450984.html
I fit 35s on my Rubicon with no lift but did trim my flares which gave me about 2" of clearance, so you should be good with the lift but will be limited to articulation
On stock wheels you will need wheel spacers.
Message spread by Paul Revere
You will need the wheel spacers. You absolutely must remove the flimsy lug retainer clips when installing wheel spacers or aftermarket wheels.
Regardless of whether you run a leveling kit, you will need extended bumpstops if you drive it off level pavement.
If you run flat flares and a 1" body lift, you need to add 1" rear extended bumpstops.
If you run flat flares and no body lift, you will need 2" rear extended bumpstops. This isn't advisable unless the rear suspension has at least 1" lift--either taller springs or a leveling kit that includes a rear coil spacer.
If you run no body lift and stock flares, you need 2.5" front and rear extended bumpstops. This usually corresponds to running a 2.5" or taller lift--coil spacers or taller springs.
Shocks limit suspension down travel. Bumpstops limit suspension up travel.
You could run 4" springs with flat flares and still rub in the rear off road if you don't extend the rear bumpstops.
You won't be able to wheel it though...I have 4" of lift and 35's and when fully flexed my tires are deep into my fenders and in danger of ripping them off if I give it too much skinny pedal.
Thats why you need extended bumpstops. I would think 3 inch extended for a 4 inch lift on 35s.
I stated the amount of bumpstopping needed for 35s above.
35s with stock flares and no body lift requires at least 2.5" front and rear.
Here's a shot of my Jeep with 35s, trimmed fenders, Teraflex leveling kit. Still need to add bumps.
Thanks, was gonna go with Level 8 Trackers/Mickey Thompson Classic style, but it seems like every other Jeep has them.
You will have to flat fender or add extended bump stops for sure if you wheel it.
This is stuffed 305/67-17 on stock bump stops and flares. 35's would not have stuffed.
I wheeled the piss out of mine on a Teraflex level lift, longer shocks, and 35s. It wasn't ideal and it rubbed the flares, but didn't see any damage anywhere. With a bit of bumpstop you'll be fine.
If you get some flat flares or trim your stock flares, you'll be fine without new bumpstops, depending on shock length. The only time I had an issue for not having bumpstops on 35s, level lift, and flat flares, was when my wife was driving 45* across a very steep creek and flexed the rear right tire into the bumper. All was well until she quit listening to me and put it in reverse, at which point the tire grabbed the top edge of the rear bumper and buckled it a bit.
34x10.50-15s, level lift, longer shocks, flat flares, stock bumpstops.
35x12.50-15s, level lift, longer shocks, flat flares, stock bumpstops.
All in, I wouldn't recommend 35s on level lift unless you go with flat flares or trim your stockers. You can bumpstop the shit out of it, but then you'll constantly be bouncing off the bumpstops and won't get nearly the articulation you could.
How are the front fenders fastened after the trim? Could you possibly post a pic showing underside of fender? I just picked up a set of 2012 fenders and want to trim them for my 2008 Sahara. Not sure how or what to use to fasten back on.
I have a leveling kit, 35's, and 1.5" wheel spacers. I wheel it and the only place it rubs is on the lip of the fender flare when fully flexed and turning.
1 - 15 of 15 Posts
