1 - 20 of 21 Posts
I recently installed a Wild Boar fastback hardtop on my 2010 JKU. It has a power sunroof, which you receive in several pieces with several dangling wiring harnesses, and ZERO instructions. Also, it has a rear defrost with harness (I did not order the rear wiper).
So first the defrost. As I had a soft top, I have no wiring or switch for the rear defrost. Since I do not have a rear wiper or washer fluid, I think the MOPAR® Factory Hardtop Wiring Kit is major overkill. Does anyone have a forum posting and parts list for a clean rear defrost install/switch?
Second, this is probably specific to Wild Boar, but if by some miracle you've wired up a power sunroof in your JK, any pointers would be great.
Thanks in advance,
Chris Page
Sorry I can't help but the top looks very cool! Do you have pics of your sunroof from the inside? :beer::beer:
Nice looking rig!
I would just setup a switch from the battery for the sunroofs. Could do the same for the defrost as well. You could also get an sPod, or call the 12Volt guy, both are really clean options for addtional switched wiring. It is difficult to locate switched and constant power in the JK due to the CANBUS system, the cigarette lighter wiring are also readily accessible,and constant/switched, but not the most ideal of situations IMO. You would be looking at a few hundred bucks to have the factory hardtop harness installed and starscanned into your computer.
I also have the fastback top, but I already had the hardtop wiring from my dual top setup.
Your Jeep looks GREAT! Congrats! :beer:
Thanks! I ordered a winch remote hardwire from 12Volt Guy a while back, I'll see what he has for the rear defrost and sunroof power. I already have a CB tapped into the cigarette lighter, so I'd prefer not to go there again...
Its just like wiring any other thing into the JK.
Use a relay and pick your switch mounting location.
Call wild Boar and ask what type of switch is needed for the sunroof, it may be a momentary switch.
Discussion Starter #8 (Edited)
UPDATE:
So, wiring the defrost, no problem. However, me and a buddy of mine (who is way smarter than I am on electrical) could NOT figure out how/where to get power to the Wildboar sunroof motor. There does not appear to be any available wiring from the motor or switch to hook power into!
Here's what the switch looks like (this mounts behind the "open/close" button on the finish trim piece):
And here's what the wiring looks like going into the motor:
Basically, I have four wires coming out of the motor, all terminating at the switch, and no obvious place to run power to (unless I solder something somewhere!)
Any thoughts on this? Am I missing something?
Thanks in advance.
Hey JKrazed, where did you run your power into the sunroof motor? Check out my pics above; did yours come the same way?
Quick question..... Where did you get your CB "whip" I have been looking for that exact set up. Thanks
Discussion Starter #11
I've got a Cobra 75WXST CB w/a CoolTech Versamount (interior mount) and what you see on the outside is the CoolTech UltraMount CB Antenna Kit w/4' Firestik antenna:
http://www.cooltechllc.com/jeep/jk_ultramount.shtml[url]http://www.cooltechllc.com/jeep/jk_ultramount.shtml[/URL]
Took about an 90 minutes to install the whole thing (antenna system, running cable, CB mounting). It looks great, no problems other than getting the antenna caught in some tree limbs once off-road. The mount is super solid.
The Versamount is a great option for a place to mount your CB mic. Jeeps don't exactly have tons of room up front to spare:
http://www.cooltechllc.com/jeep/jk_versamount.shtml[url]http://www.cooltechllc.com/jeep/jk_versamount.shtml[/URL]
Hope that helps,
Chris
Discussion Starter #13
i know the perfect fix for this...
i give you my hardtop and you give me that crappy thing thats not working correctly...
oh and my defrost works just fine
:beer:
Awesome thanks so much for the direction, also your JK looks awesome I also have a "Dozer" jeep, and was considering the Wild Boar fastback, any idea where I can view prices and options online. I will owe you big time for this one ( if you know of a site) Thanks once again for all the help ( I can use all i can get :) )
Discussion Starter #15
No problem, I don't know a whole lot myself, just learning as I go and having fun doing it.
About the Wild Boar, it was huge soap opera for me to actually get it, as the folks over there were changing manufacturers, and then other delays, and long story short it was something like 6+ months between the time I paid for it and the time I got it. I certainly assume that was a perfect storm of bad circumstances, and that the normal turn around time is a few weeks, and not half a year!
That being said, I LOVE the fastback hardtop. Coming from a soft top, it is amazing how much stability a single piece hard top gives your Jeep. On top of that, unlike the freedom hardtop with its unlined white fiberglass interior, the Wild Boar is lined inside with dark gray carpet, which not only looks good, but REALLY helps cut down exterior noise (especially if you're running off road tires on the highway :)). Lastly, the optional sunroof is a nice touch.
The only downside of course is that the thing is a BEAST to get on/off. You will NOT being doing that regularly, and you'll want either a hoist in your garage or a good (and strong) friend or two to help you. Two can do it weight-wise, but it's a lot easier to guide it on without scrapping the crap out of your paint with three.
And of course, the look is very distinctive. Love it or hate it, there's not another one around here like it.
Their web site http://www.wildboarproducts.com/fastbacktops.html has a lot of info, but you'll need to shoot them an email for a quote. You'll also want to factor in shipping, which is several hundred bucks. They do a heck of a job shipping it though:
Lastly, you can check out this post for a list of upgrades I've done:
http://www.jkowners.com/forum/showthread.php?p=1088547
Like I said, I don't know a lot, but I can help a bit with anything on this list.
Hope that helps,
Chris
<<<< Inspired ;Wow!!! what a great set up, thanks you have given me some great ideas , I will look into the FB, look forward to seeing you around
Hey Chris,
I love the look of your jeep. I have a Wild Boar on my JK as well. Sorry I couldnt help you answer any quesitons though, it was on there when I got it last summer. I will attempt to pull it off this summer for a while and see how it feels to go topless!! My wife really wants to run around with the top off...so we shall see how that goes:)
I love the sunroof option, and the rear defrost isnt even hooked up on mine. I have to keep in mind when I pull the top off to watch for the sunroof wires.
Andrew (SuMo)
I wired the sunroof of reagle's wildboar top and it had 2 wires coming out in the left rear corner - just a simple hot and ground
Discussion Starter #19
Hey, just to verify, are you positive that powered the sunroof as well? I haven't looked at it in a long time, but I was pretty sure that the power in the rear left just powered the rear defrost...
yup I'm sure, his didnt have defrost.
1 - 20 of 21 Posts
