I am getting muddled here with opposing opinions.
I am concerned about wheel to stop clearance in full turn and with tire to frame (etc) clearance in the rear.
Hypothetically what is the least amount of back spacing a person can have on a stock JK if the measured section with is 12.5 inches on a 9" rim?
I dont want the tires to stick out any further than they have to.
My old JK I had PXA7069-7973's 17x9's procomp's with 4.75" back spacing and there was a pretty big gap behind the rear wheel which made them stick out.
I can't remember how large the gap was though in the rear. It seemed to be out about an inch and a half further than it really need to be for street driving without compensating for arch during articulation. Just on a level surface.
Could I person go with a 6" back spacing on a 12.5 on a 9" rim for street driving?
Thanks in advance
Jeff
Thanks in advance
Jeff
It would depend on how tall of a tire also... especially in the front.
I have read repeatedly that stock 17" wheels are 6" backspacing so the short answer would still probably be "NO"!
With stock 17" wheels, a 1 1/4" spacer, a 35x12.50x17" tire would barely rub. I never felt it but I saw the marks it left on the rear wheel well and the front lower control arms and (I think but not sure) the swaybar also.
This was an 8 1/2" wheel but not sure if it would make much difference?
Your factory wheels have 6.25" back spacing. About the biggest tire you can put on them without a lot of rubbing and no spacers is a 285/70/17 and it is very close to the sway bar links in the rear.
The answer to your question really relies on your tire choice more than anything.
^I would listen to him. He does this stuff day in/day out.
