X2... I only run the front ones. I've never used air bumps, but they work better than the rubber knobs.I had them front and rear for a while. The front ones were great. Install was pretty easy and they worked as advertised. Not nearly as awesome as air bumps, but much better than the cheap rubber knobs.
The rear ones were way too tall. I was running 39.5" Iroks with 5" of lift and I still couldn't stuff a tire up all the way. I also didn't notice a difference in performance from the rear bumps over the standard teraflex bump stops.
I moved on them because of the way the rig behaves on off camber, tippy stuff. The suspension tends to let the rig tip & pitch a lot. One of my fellow club members has the same suspension had the same issue. Said the Speed Bumps eliminate a lot of that tendency, reduce the pitching side to side and make it more stable. I'm not much on the high speed pre-runner type stuff, but if it's an added benefit, hey, why not?I had them with the 4'' tflex lift and over-all I was pleased with them. They do IMO limit flex especially if you wheel as light as possible like no doors or top then it seems they limit your flex somewhat. that being said they seem to do a lot of good in keeping your tires grounded and less hopping. I think I would rather have them than not and flex isn't everything although it is cool. I like the absorption factor a lot when trail riding and cutting off. I have never not made it thru a obstacle because of the somewhat limited flex (cool factor) and I know they help keep the tires more grounded at speeds and during flex and crawling.
JK Neal
it will for sure fix that problem. I had my bumps set to where the front was touching the bump nearly on flat ground and the rear wasn't far behind because I had no sway bar front or rear and the bumps helped bigtime to keep the jeep from leaning to bad. Very good, I think you will like them for sure.I moved on them because of the way the rig behaves on off camber, tippy stuff. The suspension tends to let the rig tip & pitch a lot. One of my fellow club members has the same suspension had the same issue. Said the Speed Bumps eliminate a lot of that tendency, reduce the pitching side to side and make it more stable. I'm not much on the high speed pre-runner type stuff, but if it's an added benefit, hey, why not?
