If you run the TF quick-disco end links, then I've got a question for you. I know the upper link (that secure to the bracket on the front body mount), the pin diameter is .625. What I want to know, is if the lower pin (that mounts to the axle) is .625 as well.
I plan to make my own links, but I want to use TF's pins. I've already got the upper pins/brackets (PN#1601277):
Here's the kit I want to order (PN#1943705), but I hope the pins are the same size in diameter.
Anyone know for sure?
-WRM
Thanks! I'm just going to order some heims from Poly, and I've got bar stock at work I can use. I might have to machine-up a spacer too, since these pins were designed a stock-style joint.
-WRM
GO WITH A DIFFERENT DESIGN if you run larger tires!!!!
When turning the wheels at full stuff your tires rub these mounts badly. All discos with this design that attaches to the front body mounts, including the JKS, have this problem. Poly performance solved this problem with their discos. Get the Poly discos.
