2017, rhino JKU Rubi Recon
Are for the rear speakers on a 2dr on the oem single disc radio. I need to splice my converter into em for my amp.
Also when i took the cover off the dash above the radio there is a plug wrapped and taped there is that for the uconnect?
Best way to do it
Go to your sound bar and pull the covers off and the speakers. Look at the color code. Which one is positive and which one is negative. As long as you do not have an amplified system, the same color wiring will be in the plug. You can also do the fronts. All you are doing is retrieving a signal from the output of the radio. A positive and negative on the left and positive and a negative on the right. The only problem with using a stepdown or converter is you just don't have total control over your amp. I hope this will help you. I am not sure about the U-connect, sorry about that.
all my speaker wires are dark and light green/gray with yellow or blue stripes
