1 - 16 of 16 Posts
Vendor
CTM's are great, virtually indestructible. Jack is a legend in the industry. The Superior version of the CTM has been back ordered for 2 months now.
If you want to avoid the u joint game altogether RCVs are a great option and have a lifetime warranty on the entire axle.
uh ya... i think he just wants a replacement lol. Rockauto only lists the bigger one for the D44.
i know it's a common joint for the D30 though.
The CTMs are incredibly expensive, if your looking just for a replacement, get the 5-760x spicer.
If you have a Rubicon you have 2 choices:
Really expensive ~ $90/ea at your local dealer Mopar part
or
Expensive Spicer Replacement - part number 5004891 in the "Spicer Life" Series ~ $60/ea
These u-joints are a unique design. The have the cross size of one series joint and the cap size of a different one. Been through it and found an online dealer that had the Mopar ones in the low $70's. Didn't find out about the spicer ones till afterwards, but they aren't that easy to find either.
Sux - but that's the way it is!
are these ujoints different than the spicer joints run in the TJ's?
I still have some spicer 760x laying around.
i'm pretty sure on the 30 they're the same. but on the 44 they're bigger. actually i know they're bigger on the 44. i'm just not 100% sure if the TJ 760's will work.
or
i'd do these before i did mopar:
ALLOY USA Part # 1652508
Large; Front Dana 44; Front
$99.89
Add Part
or
Those are strictly for the D44 I think.
Any ideas on how to get the end caps off the stock U joint? I'm use to clips, not covers like these things have.
Sent from my SGH-I897 using Tapatalk
These have C-clips on the inside of the ears of the yokes. Pull all 4 of them then drive them like a normal joint.
Nothing out of the ordinary that I know of. Either use a joint press, or a socket and a BFH to push them out.
1 - 16 of 16 Posts
