1 - 20 of 28 Posts
I aired down my new Nitto's to 20-22lbs when testing them out on the hard frozen soil this past weekend and the ride was much nicer but thinking it may have been even better going down a little more. Thoughts?
IMO
It depends a lot on where you are wheeling as well as how much wieght you are carrying.
My 35" MTR Ks I usually air down to 15 when wheeling here in AZ.
IMO
I was basically empty but I am in an unlimited with a heavy front, rear bumper and tire carrier running 35's. And a winch too. So compared to stock, I am guessing that is fairly loaded up.
6-9 psi on 37" mtr's. No bead locks, never blown a bead.
Real men run single digits. :thefinger:
Not below the waist, shorty. :thefinger:
I'm on the stock 32" MT's and I've been going to 20psi (I run about 36psi HWY) My thought is to enhance traction and ease the stiffness, but to also keep as much hight as possible.
Should I be going lower?
I go to 16, 14 if i think i may need a little more bite. Really havent 'needed' to go down any more on the rocks out here.
In the pines I normaly dont air down at all. Out at Rausch Creek I do 18 or so on the stock BFG MTs.
Discussion Starter #14
Not sure where in the Pines you've been or when the last time you went was, but I can tell you that if you don't air down in Wharton the trails will shake your frigging Jeep to pieces. It is bad out there now. Washboard trails combined with the frozen HARD dirt makes it very bumpy.
Discussion Starter #15
...double post.
Discussion Starter #16
I almost ripped my damn antenna off the mount before my buddy handed over a bungee to use. If I had to listen to it smack the tire carrier another minute the thing would have been a javelin. :pissed:
I usually go down to 15-18, havent ever had a problem.
Also really depends on the load rating of your tires.
Stock Rubicon BFGs 12 psi for genersl trail use, 10 psi for dune sand.
1 - 20 of 28 Posts
