4 door jk is getting a 2.5 budget lift. what back space wheel works best for you running 35s. this is a daily driver. looking for best 35" wheel tire combo in others opinions.
It will be detirmined by what size and design of wheel you are looking at. The JK already sits pretty wide so I don't think you would want to go too wide. Most people do just enough to clear everything. I personally have 15" steel wheels so that required me to go with at least 4" to clear the calipers but I wouldn't think you would need to go any wider then 3.75 or 3.5 at the max. I belive 17" steel wheels you can be down to the 5" range. I think stock are only something like 6.5 so people are running spacers to fit wider tires or they will rub. So I guess the important question now would be what size/style/type wheel where you thinking about?
Here is a little info to give you some ideas.
http://www.jkowners.com/forum/showthread.php?t=510&highlight=confirmed
If you end up getting some wheels post up in that thread so others can have that info as well! :beer:
hey, why you laughing at me? It was an honest answer! :mr-t:
Just givin you a hard time btw, welcome to the forum! :smokin::beer:
the jeep is getting mickey thompson steet locks. with a RE 2" spacer lift. Tires are BFG km's. what backspace should i order to avoid rubbing. Or should I stick with a 33" tire.
if you are going to wheel it, stick with 33's. 35's will rub with only a 2 bb.
