1 - 8 of 8 Posts
Hello,
i am a owner of jk 2007
I hear a weird buzzing from the dash panel when i run after 60mph
I have check anything i can imaging may produce such a noise but nothing found.
Any suggestions?
(Not able to post link with video :frown2: )
did you or your dealer top-off your DRR* at proper interval?
*dashboard resonance reservoir
:p
:jeep2:
I will check this out , thanks
The thing is that I have my car 10years
And never had this problem
The last modification it was a sprind booster
This has been covered in quite a few threads here o JKO .
More than likely heat shields on exhaust manifolds , welcome to JKO .
Good Luck .
Might also be worth checking for objects accidentally dropped in the space between the dash and the windshield. Sometimes small objects can fall in and rattle around. I had a 10mm wrench drive me crazy until I was able to find it and get it out of there.
I'm from Greece but I bought it directly from California, it is with miles etc .
My thought is if Jk's have any buzzer at all? And I mean buzzer not the sound indicator like this for belt or tires.
Grab a small wrench and bang on the heat shields of your exhaust manifolds especially the one on the right side of the Jeep , what you will find is a loose or rusted screw or bolt on the heat shield .
This is a common complaint , the vibration will cause a buzzing noise like you describe .
1 - 8 of 8 Posts
