I have a 2009 Jeep Wrangler. For no reason several warning lights came on at once. I checked the battery the voltage is good. I also cleaned both terminals. I started the Jeep all the lights went off but they came back on about a quarter of a mile down the road. Any help would be great.
Check your grounds and maybe a pic of the Christmas tree. Any codes?
If you have the electrically controlled front swaybar disconnect, water in the connector can cause this issue. I removed mine and replaced it with a non-disco sway bar and bagged the connector. All is good now.
