I've had this idea for awhile, but I'd like remove the power port and replace it with a USB port. Seems like 99% of what I plug is a USB cable to charge a device. The only exception is my GPS and I can use the 2nd port for that one. Is there an aftermarket kit that already does this? I was headed down a path of taking an aftermarket carcharger and hacking it to fit, but then with the newer jeeps already having USB charging I figured that someone had already come up with a replacement option. Thoughts?
Sent from my iPad using Tapatalk HD
Whatever you do, don't leave anything, at all, plugged in 100% of the time on the "always hot" passenger side port. There have been numerous burn-downs from doing that.
Just installing something like a USB charger that accepts different cables would be the easiest and leave it in the cig lighter. No real need to over complicate it more than that.
