1 - 20 of 29 Posts
I live in NC and spend quite a bit of time beach running. Problem is, dropping the air pressure in my tires is becoming quite "tiresome" as I have to bring an air tank to get them back up to a reasonable pressure to get me to a station where I'll spend $5 getting them where they should be. Found several online, but with few pics of them installed. Hoping y'all who have them, could post some pics and give your opinions whether you like them or not, or even if it's worth the trouble. Keep in mind, mine is a '15 Sport, so no lockers.
Sent from my VS988 using Tapatalk
Nice kit! Looks like most I've seen mount to the master cylinder. Is that where yours mounts?
Under the hood is not a great place to but the compressor because of the extra heat and to a small issue adding more weight to the front of the vehicle. If you can find the room mount it in back where you can easily get to it.
Thanks for the input! All opinions are appreciated. This IS something I'm going to do, (unlike plasti-dipping my wheels, lol) so the more info I get, the better informed decision I can make!
Due to Underhood heat, IF you mount the compressor under there you should have the good open and the engine OFF when running the compressor to fill tires.
I have MORE Dual battery mount so electrical drains like that aren't something I worry about. But I am concerned about keeping my compressor from over heating. I have sent portable compressors into thermal shut down before due to heat and duty cycle. Even though I have upgraded to a constant duty compressor (100% duty cycle) I have it mounted inside over my rear wheel well.
I would not put it under the hood either. If you look at the specs of the compressor it has a normal operating temp. at around 150*. With your engine running around the 200* mark and the air temps under the hood you are at or over the normal operating temperature of the air compressor before you even start to use it. You will pre-maturely wear it out and\or blow fuses when you start to use it. Almost everyone I know who has an ARB or comparable compressor mounted under the hood has blown fuses. An overheated compressor will draw more amps.
  • Like
Reactions: Tenderfoot752
all of this discussion and questioning of where to mount a compressor ( heat under hood) or how to find-room inside( I wheel with a 37" spare in the rear cargo area & use underseats for hiLift, tools, guns, & a bunch of other stuff so,really,there's no room ) to place it without shelling-out $500 for the swank, under-seat dual comp ARB thing is why I said to heck with the OBA ( even tho' I would really like to have it)and just spent a little more for the highest CFM portable compressor available and just fit the viair 440p wherever I can, usually lashed-down in middle of the spare with a strap.
I'm just chiming-in because of irony; I was searching just this past weekend - again-
for some possible way to get the thing either under hood on a mount-bracket(440p gets too hot&is too big I think) or ( as theDirtman wisely suggests) atop wheelwell in back ..I believe the wheel-well is the only location I could get the thing mounted to. I know as hot as my Jeeps exhaust-mani gets I sure don't want a compressor that has it's own exhaust tubes sitting on top of it, to be sure. So, I cont to just lug it around.
I have a 2dr and removed the back seat (it will never go back in). I would have been content with a Viair portable after finding the short comings of cheaper compressors. But '12+ automatic transmission JKs have use a selectable locker in the rear. I ended up getting an air locker so I needed OBA. The 450 OBA kit was a Christmas gift. If I was buying it I would have gone with the 430 or 440.
Am running the ARB twin with the M.O.R.E mounting plate under the hood. Below is a link on how and where it fits with an sPOD next to it which is my current setup.
https://www.mountainoffroad.com/arb-air-compressor-mount-07-14-jk.html
As for the comments of having it mounted under the hood, I have had no problems in the two/three yrs its been mounted and used from under the hood. While airing up I leave the hood raised and have had no problems with any component of the system. Some people put it under the passenger seat. I did not do this because SWMBO'ed normally sits in the JEEP while during air up. And NONE OF US WANT TO HEAR how loud and annoying the air compressor is during a two hr ride home. Do we? Have read about people mounting them in the back of the Jeep but again, the noise during air up and then the "noise" on the way home to which NONE of us want to deal with makes the under the hood install, IMO, the best option.
Mine is also run through the sPOD. Some people put the switch next to the unit under the hood.
M.O.R.E and Rebel Off Road have install videos you can view. Just gotta google 'em.
Oh, wheel 37x13.5 R17s. Lots of volume to air up...never timed it but from 10 PSI to 30 PSI takes about 3 minutes per tire at an elevation of 2600'.
Powertank is an option.
i have always gone back to this , Fred. Cost is one factor for me but more than that is having to find a welding material shop to get it refilled + stories of those same places wanting to swap your nice power tank with a prefiilled one but I guess that depends upon the location . Still gotta mount it or make room . The air tool option is nice,admittedly.
Discussion Starter #13
Thanks for the input, guys! A lot of valid points for and against, so I guess it really just comes down to personal preference and application. So, when I make my decision and install, I'll re-open this thread.
Agreed. I have my dual ARB under the hood with no issues. Was on the MORE mount but had to fab one up as the MORE mount didn't fit with the larger brake booster for my oneton swap. Still somewhat same position just farther forward. Running it with a Switchpro and a remote chuck mounted on the bumper.
Respect a lot of what you post but that's too much. Come on, the ARB kit only weighs like 20lbs.
[QUOTE
Respect a lot of what you post but that's too much. Come on, the ARB kit only weighs like 20lbs.[/QUOTE]
It all adds up. Weight distribution is often over looked on builds until your done.
That's surely a second reason to buy one.
I didn't initially get mine 15 years ago for Jeepin' but, since I have it, it's come in handy in that role. Recently, I picked up a 5lb aluminum bottle from my welding supply shop. It's definitely more manageable in the JK but I haven't gotten around to installing a mount. It gets strapped down to the rear floor (no seat) along with the the fire extinguisher, just like I did with my 15lb PowerTank.
As you mentioned, finding a gas supply can be an issue. My local welding shop has been good to me. I always get my bottles back. Filling and testing, when needed, is about $15 each for the 15lb-er.
The third reason, an advantage that has come into play numerous times, I can use 'em anywhere. I top off all the tires in my quite sizable stable of vehicles (lawn tractor, quad, four trailers - one of which has a tire machine, a dozen bikes and four vehicles), it goes from the basement shop (with pneumatic bike lift) to the garage and to the back of the 'Vette for midnight roadside rescues...nothin' like whippin' out an air gun on the side of the highway when your buddy's gooseneck blows a tire during a delivery at three in the morning. ;)
Everyone's needs are different. I'm fortunate to have already had the Powertank. It's fulfilled the subsequent Jeep usage well enough that I can't imagine ever installing a "light duty" compressor for less utility.
I like the MORE one for doubles. I have a single ARB mounted with the EVO mount on the master cylinder. Then I made a custom over engine mount for two twins. The connectors get hot. I am going to run a stainless line to the exterior to keep it cooler.
You can see the single compressor under the manifold where all the air lines tie in.
I had an oba(Viair), worked well, about 3 minutes each tire. Then bought a smittybilt portable from 4wd.com, love it because I can take it in either vehicle. Now though I want a Power tank(orcheaper version like smittybilt). The buddies I wheel with swear by them. Fills up FAST! Around a minute each.
Sent from my XT1650 using Tapatalk
5 air compressors is the most I've seen , I believe; one for each tire and then one for the locker activation ? you're in a different league altogether, Keith, heh :bow:
I have the ARB twin compressor mounted under front passenger seat. I have lockers and its not too load and barely turns on except the initial fill and that's for less than a minute. It also airs tires up relatively quick and can run air tools.
1 - 20 of 29 Posts
