U1417 & U1418 codes
70K views 20 replies 8 participants last post by  Miguel b
#1 · (Edited)
Did a little light wheeling out to go fishing yesterday, nothing crazy by any stretch.
Now getting U1417 & U1418 codes - "implausible wheel distance signal" codes for both front wheels? (edit: I assumed front but it just says left and right)
A quick peek under the front end and everything looked ok - wheel speed sensor wires werent ripped out or anything.
I'll look closer this weekend and try a computer reset and see if that will clear it.
Just wondering if anyone had any insight on getting both at once?
I'm familiar with getting ABS/ESP lights for off center wheel, bad unit bearing, etc but this is a new one for me.
#3 ·
#5 ·
Here is some info for the codes you have.
It may not be a sensor at a wheel unless you also have a sensor code.
U1417 and U1418 have the same possible causes.
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
When Monitored:
Ignition on.
Set Condition:
The PCM gets an implausible signal over the CAN C circuit from the ABS Module. The circuit is continuously monitored. One Trip fault.
Possible Causes
VEHICLE SPEED SENSOR FAULT ACTIVE IN ANTI-LOCK BRAKE MODULE
CAN C BUS CIRCUIT SHORTED
CAN C BUS CIRCUIT OPEN
ABS MODULE
POWERTRAIN CONTROL MODULE (PCM)
#13 ·
nah man, I appreciate your attempt to help, but like I said, it really doesnt tell me anything
just went through the underside, all the wires look good - nothing mashed or pinched.
so we're left with some sort of digital problem I'm guessing?
ABS module was supposedly replaced in January (not under powertrain warranty of course) because it kept nailing the right front brake for me - I think the problem was actually the left front WSS in the toasted unit bearing.
but anyway, it should have a fairly new ABS module in it.
So I'm left with paying the dealership to hook it up to the chassis scanner to tell me whats making the canbus unhappy?
#14 · (Edited)
Troubleshooting the Can Bus requires the Dealer StarScan tool.
The good thing is, if it's a bad ABS module, yours should still be under the 1 year new part warranty.
Mark yours with a permanent marker in a hidden location (just a dot) before you bring it in.
#17 ·
Thanks for the reply. I have a couple more questions.
1. How much was the part if you can remember? Do you have the part number?
2. How did you determine if it was front or rear since the U1417 only refers to the left side. I only ask because I have replaced my left front and left rear sensors, and the left rear is where I found broken wires in the harness, which have since been repaired but I still have the lights.
#18 ·
Mopar part number is 52060398AC
Usually a little less than $100 and easy to change.
I determined it was my front because when I jacked up that corner, the front wheel flopped around about 1.5" so it was pretty obvious. But not while driving. No shimmy or noise.
#19 ·
This is going to be quite the bump on this old post but I have a 2009 Jeep Wrangler JK, 108K miles, I have been getting the BAS ESP ABS lights stay on steadily for a year now. I would love to hear any more ideas/solutions people have to the U1417 codes - "implausible left wheel distance signal". Here's what has been done thus far:
1. Chrysler mechanics analyze, scan and have my jeep for a week... call the 'expert' at Chrysler and still no answers, they completely wire directly from the left rear abs sensor to the computer. Had the lights off for a day, then they came back on.
2. Replaced both rear abs sensors, checked for cracked wires(no cracks)
3. Replaced driver side front wheel hub and sensor
4. Replaced clock spring
5. After every attempt to apply the fixes, the codes where reset using Superchips FLASHPAQ 3872
Any suggestions/solutions appreciated?
#20 ·
I just replaced my right rear sensor after getting the U1418 code. I had a time get the "red" clip off. Maybe there is a trick to it. I considered using dielectric grease but decided against it. I pretty much installed it based on feel because I couldnt see much while I was working on it. Indicator lights when off immediately after I rolled down driveway and made the turn down street, so it must take a few rotations to register.
