Twistwd AntiRock
2355 Views 32 Replies 8 Participants Last post by  cdc12372
Has anyone has an issue with twisting the arm on the front Currie Antirock.
Driverside is real bad and passanger has a small twist. The bent at the bend in the arm. The arms have full clearance and don't come in contact with anything.
Current set up is RK 5.5 mid arm and PP steering linkage on 35's.
1 - 20 of 33 Posts
Do you have aluminum or steel?
mine hit the body mount all the time and i have to constanly make sure they are tight or they will jump teeth on the rod
still not impressed
I cut out that far side of the body mount brackets on install of the Antirock.
I had no issues with my old lift "4 inch superlift" This was the first run with the RK.
you got pictures boss
if im getting you right you twisted this part
Yup thats what bent, both sides. I will see if I can get out to take a pic in a few.
We have run them on two of our JKs with no problems. We had problems with the rear arms but they have fixed that with different rear arm.
id be sending it back to them im sure theyd take care of it they sent me the wrong endlinks they charged me shipping but they sent the right ones out
I will be calling them later, but I still want to run that set up. I want to find out why this happend still so I can fix the issue. I know there are a few on here with those, and I wanted to see if I missed something?
Really like to see a pic. Curious how it happened/
Not the best pic, but this angle shows the twist.
Just looked at mine and they are as straight as the day I put them in. The left rear is running real close to the trackbar bracket though. I have some suspension mods I'm hoping to get to this weekend. I'm going to take a very close look at the Currie's then.
That's some serious ****! Could you have articulated your axle so far down that the arm bounced off a rock or something? I'm having trouble picturing how that could have happened.
1500' above you. :beer:
I thought the same, but there are no signs of impact on the arm? The trail I was on is a very mellow trail, lots of woops, not alot of rocks. I just wanted to compress the new springs a little and get the new arms to flex out before a more challenging trail.
I'll be as high as you someday:beer:
how does it look at full compression when articulated? MAybee the angle of the axle and the length of the links? Are there rub marks on the side of the antirock arm or am I seeing stuff?
Kinda hard to visulize from the pic
Yea the sticker has a rub mark on it from the tire, but that was from the day of insatll moving my Jeep to a different bay before install was complete.
I don't have any pics of full flex, but I see were your coming from on the length of the links. I may put a tire on a lift and watch it as it flex's.
It just looks like it's been compressed. Still can't figure how. Could Currie have forgotten to temper these?
Yah, only thing I could imagine it when it is articulated out. Probably on the compressed side but who knows. Thats a guess from a picture, lol.
im betting you put the brackets that the white busings in are bacwards
check and make sure the busing part is to the front
it looks like it hit the spring pocket
1 - 20 of 33 Posts
