141 - 145 of 145 Posts
· Registered
Do they replace the factory horn pretty easily? I assume they don't just plug and play, but is there enough room in the factory mounting location for these? Can you just splice into the existing horn circuit to run these?
· Registered
If you wanted to use just one where the factory one is , it would be easy. I havent figured where im going to mount mine yet but it should be a fairly easy mod.! :gluging:
· Registered
I was checking out placement for mine today... I figured one on the oem mount and one just on the other side where the esp is bolted on. I'll just use that bolt, hopefully! Lol I'm not really sure about wiring yet.. I will have to pull the oem horn out to figure out if I can use that relay and if I need to fuse it separately... We'll see! If anyone has mounted these and has some tips I'd appreciate it for sure!!
· Registered
I was thinking about that yesterday. Im going to check what fuse it already has on it and go just splice these in and remove the stock horn. Should be really easy. I think the horns are 5 amp and I imagine our shock horns are not any more than that.
I may have to pick up a set of these.
I suggest it! They are awesome quality I forgot to mention. They are solid and made of metal no cheap plastic stuff.
