Right turn signal on '08 JKU stopped working. Took out bulb and it was dark. Replaced with new bulb. Still not working. Just getting an intermittent flash when turn signal is on. Anyone have similar issue? Possible ground problem?
Thanks
Turn Signal
Hi,
Thanks for the reply. I replaced the front signal and the rear began to flash intermittently. After it stopped flashing, I replace the rear bulb again with the good one from the front. No flash in the rear and the front runs fast like it has a partial load.
Gunnery Sergeant USMC (ret)
I would start by moving the other side to the side that is acting up right now. If it does the same thing then there is something in the wiring. If it stops doing it then it is the bulbs.
