Does the 09 JK have an actual flasher relay that can be replaced? If so where is it located and how do you get to it? I hear the "clicking" like a flasher would do but it sounds like it is coming from the instrument cluster. I looked in the owners manual and see no mention of it which leads me to believe it might be a computer function of the EEC..any and all input will be appreciated. Thanks in advance for your time to read and reply.......Don
The JK does not have a flasher you can change. The clicking is coming from a piezo speaker on the cluster board, I removed mine.
Are you freakin serious? Where is it located?
Sorry I removed the door and oil change (dinger) reminder piezo. I dont remember which one is the turn signal piezo, but it is on the board.
I had enough on one trail outing and did a dinger extraction in the field. remove the instrument cluster and take the back off of it the dinger is on the left side just grab it with a pair of pliers and twist.
