I've done some searching but thought I would ask about some specifics. I have a 2013 Rubi with 33's and no lift (can't get it in the existing garage if I go ANY higher). I no longer have TPMS sensors and definately want to turn off the dash light. I plan to eventually move to 35's and regear the diffs at that point. I think a ProCal will do most, if not all of what I want to do.
I did notice a difference in 6th gear after the wheel and tire swap, even with the minimal duratrac tire size bump. I know some other programmers do more. Such as superchips, hypertech, Diablo, etc... I wouldn't mind regaining some of that 6th gear drivability I lost. However, I think a lot of those extra advantages you get with other, more expensive tuners apply to the automatic transmission. Are there many benefits, or justifiable reasons for buying something more than a ProCal if you have the stick shift?
Thanks
most of the "power" gained from a chip or programming is done through changing shift points if I'm not mistaken. (I may very well be mistaken) we went through that discussion on a truck site a number of years ago.
your 6th gear drivability suffered a little due to gearing, best way to get it back is by regearing it.
Thanks. Those are my thoughts too but I have seen some folks that said they got better usable power even with the stick shift. Maybe? it isn't bad enough to justify regearing right now.
I hope to get some feedback from quite a few members and maybe even some that have direct experience with this type of setup.
i have a 2011 JKU rubi 6speed. i started off with the procal. it worked great. i have since switched to the superchips trail dash. i highly recommend the TD if you have a rubi. the ability to use lockers in 4hi and use them independently is awesome and worth it. although it is pricey
Some units do have some bells and whistles for the Rubi. I like the idea of using the lockers in 4wd hi. Not to go fast but sometimes lo just isn't needed. I think you can do swaybar disconnect I 2wd too and that would be good on the trails around here. Not sure it's wort a $300-$400 premium over the ProCal.
You mentioned ndependent locker control. I assume you mean the added ability to use front locker only? Thanks
As soon as I hit a trail, swaybar disconnected smooths out the ride substantially. Even when 4wd isn't needed.
