1 - 2 of 2 Posts
rig worked when parked last night. this morning i depressed the clutch pedal, which feels 'normal', and it tried to start in gear. no apparent leaks. brake reservoir not low. no unusual sounds when clutch pedal depressed. broken clutch fork? slave cylinder malfunction?
if i had hair i'd have pulled it out by now. can't put the trans in gear if the clutch pedal is depressed, but will if it's not.
1 - 2 of 2 Posts
