1 - 8 of 8 Posts
anybody have any suggestions or pics of where they put their brake contollers? and does anybody know if a prodigty contriller needs to be mounted flat or close to it?
I have a Prodigy Brake Controller. I mounted it down by my right knee. Here are the photographs. I believe Prodigy recommends a 30 degree angle. Works good!
Works well in this location.
First I used 3M double sided adhesive and then I added the two bolts.
i migth move it up on the dash, i hardley ever tow so id just put it there when towing
I have a prodigy and mounted it right under the steering wheel, it's out of the way and easy to get to, I will try to get you a picture tonight.
its easy, just need a 12v, the brake wire(forget what color it is but i can go look) and a ground, then run the wires back to the plug
1 - 8 of 8 Posts
