Since I have moved my rear axle back a bit more than 1 inch my rear track bar is no longer in line where it needs to be and I am having rubbing issues with it. I have been searching sites for some hours looking for a track bar frame mount so i can cut my factory one off and weld a new one on farther back. every part I run into are either just braces or relocation brackets for the axle side and I need frame side. anyone able to point me in the right direction? thanks!!
Thats a great idea thanks for the link to that but adding another piece to move it farther back is not my only problem the frame mount actually hits the back part of the axle bumpstop so I need to remove the front of the stock mount maybe ill try and add a piece and notch the front part out thanks for the links.
http://www.jkowners.com/forum/showthread.php?t=35749&page=14
He just added a plate on the outside. Pretty easy to fab up.
