1 - 8 of 8 Posts
hey can u move the TPMS to aftermarket rims?
Yes, as long as they will fit the new rims.
are they like the aftermaket ones where you have a band clamp to hold them in place? do they fit on pro comp rims? im going to run a 17in rim same size as factory.
Mine wouldn't work on my ProComp steel wheels so I just turned off TPMS using the AEV ProCal. No more problem.
No, they are the valve stem with a rectangular box on the inside. That's the thing if they will mount in the new wheel without obstruction.
Mine have been swapped into 2 sets of wheels since the stock wheels. No problems. Currently on a set of Cragar Soft 8's.
i had them swapped out into my procomp 8179s when i switched... but then realized i was going to be running a much lower psi so i used the AEVprocal to shut off the sensor. also... my procomps are 17" you should be fine.
1 - 8 of 8 Posts
