Looks like it's working to me.
I read the same posts. it is possible but it take a little effort.
I have the same wheels/tires and am thinking of adding the rings.
I have the rings on mine and yes they are a bitch with the Toyos....i use a solution of dishsoap and water and slowly work your way around in a criss cross pattern..... DO NOT overtighten the bolts as they strip real easy....don't forget blue loctite....mine occasionally still come loose so check them often. Once you drive with them on the tire bead will look even.
