1 - 11 of 11 Posts
I may have the need to tow my Rubi for about 300 miles. I was wondering if I can put her on a tow dolly (with TC in N and manual tranny in gear as the owners manual says) or would I be better suited with a trailer?
I will be towing it with a Chevy Tahoe (tow package, boosted suspension).
Anyone have any experience with this?
Thanks
Hook it up. Be sure the straps go around the tires if they are bigger
Sent via paper airplane
Check out your owner's manual. I am quite sure it says that you can NOT put on a tow dolly. You can either flat tow (4 wheels on the ground) or put it on a trailer.
Oh, and first post - w00t!
This is all it says about dollys
TOWING A DISABLED VEHICLE
The manufacturer recommends towing with all four
wheels OFF the ground. Acceptable methods are to tow
the vehicle on a flatbed or with one end of the vehicle
raised and the other end on a towing dolly
I certainly can't speak to all years of JK, but I have had an 07, 08, and '11, and they have all pretty much said not to put on a dolly. I would refer to the manual for my year to the definitive answer. If you CAN raise one end and put the other on a dolly, as mentioned, that would be kind of like on a trailer, since all wheels would be off the ground.
I still contend that towing on a dolly - with two fronts off the ground and two rears rolling on the ground - would NOT be good.
The '11 manual says:
Caution!
* Do not attempt to use sling type equipment when towing. When securing the vehicle to a flat bed truck, do not attach to front or rear suspension components. Damage to your vehicle may result from improper towing.
* If the vehicle being towed requires steering. the ignition switch must be in the ON/RUN or ACC position, not the LOCK position.
Four–Wheel Drive Models
The manufacturer recommends towing with all wheels OFF the ground. Acceptable methods are to tow the vehicle on a flatbed or with one end of vehicle raised and the opposite end on a towing dolly
If flatbed equipment is not available, and the transfer case is operable, the vehicle may be towed (in the forward direction, with ALL wheels on the ground), IF the transfer case is in NEUTRAL and the transmission is in PARK (for automatic transmissions) or in gear (NOT in Neutral, for manual transmissions). Refer to “Recreational Towing” in “Starting and Operating” for detailed instructions
Caution!
* Front or rear wheel lifts should not be used. Internal damage to the transmission or transfer case will occur if a front or rear wheel lift is used when towing.
* Failure to follow these towing methods could result in damage to the transmission and/or transfer case. Such damage is not covered by the New Vehicle Limited Warranty.
Do this $139 bucks just finished loading it few hours ago..tow pig is 2010tahoe ImageUploadedByTapatalk1307594046.585902.jpg
From the 2011 Wrangler Owner's Manual, page 469....
RECREATIONAL TOWING (BEHIND MOTORHOME, ETC.)
Towing This Vehicle Behind Another Vehicle
Flat Tow
• Automatic transmission in PARK
• Manual transmission in gear (NOT in NEUTRAL (N)
• Transfer case in NEUTRAL (N)
• Tow in forward direction
Dolly Tow
Front NOT ALLOWED
Rear NOT ALLOWED
On Trailer ALL OK
Mabar
Bumping this from the dead.
Need to tow mine on a dolly. Can't see any issues with towing it this way. I have a 60 front with locking hubs and flat tow it all over the country with hubs unlocked. So it's not an oiling issue. The only thing I could think is they are worried about the tcase slipping into gear and could kill it but want be an issue for me with the hubs unlocked.
Thoughts.
You can just disconnect the rear drive shaft and tow dolly it without issue. O'course I didn't tell you to do it if you puck it up!:thefinger:
Thoughts.
My thought is: Do it and tell us how it worked for you.
There are lots of people who have asked about doing this even though the owner's manual says not to.
1 - 11 of 11 Posts
