We have a 2015 Rubicon Unlimited on the way and will use it as a Toad.
I want to have a winch too with the stock bumper.
Has anyone done this or have info?
All help will be appreciated, Thanks. quadnkev:)
Lots of different ways to go, factory Mopar, Rugged Ridge, you pick a name there is probably a mount to run a winch. Look at your local dealer or pick a catalog and there is a mount for the factory bumper.
I use:
Rough Country - Front Hybrid Stubby Bumper $229 on Amazon ($189 without fogs)
MBRP D Ring Bracket Mount Pair- $99
Warrior TOW BAR D RING ADAPTER(s) $75
Tow bar of your choice. I had one already.
You could run any kind of winch you want on the bumper, lots of plates out there to use a winch on the stock bumper.
My old man runs this blue ox on his 13 Unlimited. Doesnt interfere with the bumper at all.
http://blueox.com/bx-r-BaseplateProducts.aspx?ProductId=1100
Its low, under the bumper basically so doesnt interfere with a top mounted winch. Install was super easy.
The other way to go is a new bumper that has shackle mounts and use those to tow with. Check with the manufacturer to see if theirs are rated for this. I am pretty sure Poison Spyder says their's are OK to do this with.
I use:
THIS! I bought the Currie tow bar mount, but wish I would have gone with the bumper posted above.
Also, get the Cooltech lighting kit. Don't even bother with anything else for lights.
Also also, I personally think blue ox is way over rated and way over priced.
