On what? Are you talking about adding JK Rubicon D44s to something or is this on a JK Rubicon.Have there been any write-ups or wiring diagrams to show how to control the JK Rubicon D44 lockers with the locker switch that comes with the TJ Rubicon?
I'm talking about adding JK Rubicon Axles to a 2004 Jeep TJ Rubicon. If I could keep the axle lock switch that is already in the dash of my TJ Rubicon to control the electric lockers in the JK Rubicon axles, that would be great.On what? Are you talking about adding JK Rubicon D44s to something or is this on a JK Rubicon.
I don't know about the blinking, but I don't think it would be that difficult since you would just wire it direct using relays. The JK is, of course, electrical and uses an indicator for locked/unlocked. I'm pretty sure it would be easy to determine what the indicator reads back out and have that relayed back to the dash lights for the locker indication.I'm talking about adding JK Rubicon Axles to a 2004 Jeep TJ Rubicon. If I could keep the axle lock switch that is already in the dash of my TJ Rubicon to control the electric lockers in the JK Rubicon axles, that would be great.
Getting the 'front axle lock' and 'rear axle lock' lights in the guage cluster to flash while trying to engage or disengage and then remain constant when locked would be a plus too.
I'm really not that familiar with how the TJ Rubicon switch works either, but with some more research I could probably find more info.
How come it was so hard for me to try to say the same thing?The lockers are pretty basic 2 wire circuits and the axles have a locked indicator, so I would think it should be pretty simple. I don't know the TJ Rubi wiring, but I would have thought it would not be difficult to set it up for the new 44's.
That's what I would of thought also, I don;t think it should be difficult.Sounds like I should be able to make it work by running the wires from the TJ switch to the front and rear lockers instead of the front and rear air compressors that power the TJ lockers. And then run the JK indicator wire from the axle back to the TJ indicator wire.
They're still assumptions though since I haven't taken the switch and locker wiring apart yet.
