I'm currently stock and running a 275/65r18 and the tires are brand new. Want to put on the 3.25 inch lift and want to know if I can run that tire size until they wear out or if that's to small and would create a drive ability issue?
You wont have any drivability issues as a result of that tire size and lift.
You will have a lot of room making it look a bit goofy
You can have drivability issues from the lift alone if it is not installed correctly.
Other then looking dumb you may have some light steering feel depending on what lift you are planning on installing. Not sure why you would be looking at lifting it that much for such a small tire, really not going to gain anything with the lift.
