Has anyone managed to find a a wiring chart of the multi-plugs on the bottom of the TIPM yet?
I can help you get the Connector drawings with Cavity name....wire colors....wire location etc...
http://connectors.dcctools.com/details.htm?id=77643
http://connectors.dcctools.com/details.htm?id=77844
http://connectors.dcctools.com/details.htm?id=77850
Like these? you want?
MODULE-TOTALLY INTEGRATED POWER C7 - BLACK (IP) 50 WAY
Mopar Package #: Not Available
CavCircuitGaugeColorFunction
L5318DG/WTBRAKE LAMP CONTROL OUTPUT 1
F2020PK/WTIGNITION RUN/START CONTROL OUTPUT
W1720BR/DBREAR WIPER PARK SWITCH SENSE
L6318WT/DGLEFT REAR TURN LAMP DRIVER
L5418WT/YLRIGHT STOP LAMP DRIVER
P3720LG/TNSWITCH RETURN
L6218WT/YLRIGHT REAR TURN LAMP DRIVER
P80720LG/LBINVERTER SWITCH SIGNAL
G7720VT/GYLEFT REAR DOOR AJAR SWITCH SENSE
G7820VT/ORDECKLID/LIFTGATE AJAR SWITCH SENSE
G7620VT/YLRIGHT REAR DOOR AJAR SWITCH SENSE
R5720LG/GYDRIVER SEAT BELT BUCKLE SWITCH SENSE
D7120WT/DBDIAGNOSTIC CAN C (-)
D7220WT/LBDIAGNOSTIC CAN C (+)
D26420WT/ORCAN IHS BUS (125K) (-)
D26520WT/GYCAN IHS BUS (125K) (+)
B2020DG/ORBRAKE FLUID LEVEL SIGNAL
G16120VT/LGLEFT DOOR LOCK SWITCH MUX
G16020VT/DGPASSENGER DOOR LOCK SWITCH MUX
L89918WT/DBREAR FOG LAMP FEED
N420DB/WTFUEL LEVEL SENSOR SIGNAL
W720BR/GYWIPER PARK SWITCH SENSE
L9120WT/DBHAZARD SWITCH SENSE
L5120WT/TNBRAKE LAMP SWITCH OUTPUT
G7520VTDRIVER DOOR AJAR SWITCH SENSE
G7420VT/WTPASSENGER DOOR AJAR SWITCH SENSE
Hello there, I am needing a diagram like the above ones listed SirCody but mines dealing with a wire has came out if the bottom of the TIPM. This is on a 2007 3.8L JKU - Wire color is a Light Grey w/ Blue Stripe. I believe it belongs somewhere in the ABS module power area but im really looking for the pin connection # so I can plug that sucker back into the connector side and then plug it into my TPIM and hopefully see positive results. If anyone could help would be great.
