1 - 20 of 23 Posts
what is everyone's thoughts on one ton tie rods or heavy duty tie rods? which do you prefer and why. Im currently running the MOPAR DANA 60'S and need some beef on the tie rod. Im already running the rubicon express HD drag link and flip kit.
RuffStuff or Carolina Metal Masters not got the beef you'd require for such a mighty axle ?
http://www.carolinametalmasters.com/products/tie-rod
http://www.ruffstuffspecialties.com/catalog/merchant.mvc?Screen=PROD&Store_Code=ruffstuff&Product_Code=TRESTAND-KIT&Category_Code=STEERINGKIT
I highly suggest you speak with Marcus of River City OffRoad , a vendor on here of renown , as he is running the same axle and has 'steered' hundreds ( if not thousands) of us in the right direction for our parts needs .... you will be a happy customer ....
If you are looking for more strength than 7/8 one tons we just became a Rare dealer and we are starting to build with their 1.25" forged Cartridge TRE'S.
Our center section will be 2" 7075 solid aluminum. Building our shop rig with a Dana 60 in the next week.
Any pics or more info on these?
I dont know if Synergy makes one that will work but it has been the best tie rod of the stock, 2 ruff stuff, and a RK tie rod that I went thru. If they make one that works with tons thats the way I would go.
Mopar 60 front uses stock size TR and DL so Synergy stuff should work without issue
Beef.
yeah, I forgot about Rare Parts; I think those rod ends are like the strongest going, or one of them.....i'd be surprised if Synergy couldn't accommodate your needs.
JonJames
Did you find a steering set up yet? If the factory tie rod and drag work in the Mopar 60 then we have 2 options for you. We are now offering our 1.5" Solid 7075 offset tie rod and a matching flipped drag link from the same 7075 solid material. The full set up would run $799 for both. In addition we are going to be making a Extreme duty set that will be 2" 7075 tie rod an drag link with the Rare parts 1.25" Forged cartridge ends for $1399.
That is bad ass.
I have a Synergy on my UD60 and I am going to go to something a little larger in diameter based solely on the axle tube dwarfing it. lol It is fine, but I am a little on the picky side. :)
I will post pictures in this thread for the Set up we are doing on our shop rig....05 Dana 60 and we are doing a 2" version with Rare parts
Will this fit a 15" wheel with 3.75 backspacing?
Or do you guys have any suggestions on the ones that will work with 15" wheels?
Sorry for the hijack..
Thanks!
Synergy may work.
Thanks!
We have not installed this on a rig with 15" wheels yet so I cannot tell you it will work. How close to the factory tie rod do the wheels come?
There is about 1". The calipers fit without any issues. I'll try to get a picture today.
1 - 20 of 23 Posts
