Hey gang i have to replace my bent tie rod. I am going with OEM (cost vs safety right now)....and i was wondering how hard is it to replace? I know i undue the TRE's and the whole thing should be fall out (i am guessing with mallet help) and then i bolt the new tie rod (i am pretty sure it comes with stock TRE's) in? Will it need to be adjusted or does it come set to factory specs? how hard is it so bang it out? Can i do it in my parking lot or should i go to u-fix it and rent a bay? Any feedback would be greatly appreciated as i have a DW that pops up at 60mph and i need to fix the bent tie rod ASAP
No big deal to replace. Take off the mounting u-bolts for the steering stabilizer, undo the nuts on the tie rod ends, and remove. I whacked mine with a 5 lb. sledge, and they came right out. You can do this without messing up the tie rod threads, but it doesn't matter since you are replacing everything. If your tie rod is too bent to get a decent measurement, perhaps you can measure one on another JK. I replaced mine with an aftermarket tie rod, got it close to the oem center-to-center measurement, then checked the toe-in measurement a couple of times after bolting it on, and adjusted 'til it was dead on. This is definitely a driveway project, with no special tools needed. It helps if you have someone to help with the toe-in measurement, but I did it alone.
