ok so after tearing into Zack Massey's 2012 Rubi for a Poly stage 3 lift and a few other goodies, I learned some things that they did different on the gen 2s.
Thanks to Zack for trusting me to take a plasma cutter, welder, grinder and cutoff wheels to a new Rubi with less than 2000 miles on it!
Anyway, changes to note....
front brake lines are routed drastically different and have a big metal bracket glued to them.
If you spray a little adhesive remover in between the bracket and the line, wait a minute then spray in some WD-40 - the brackets will slide off of the line leaving a MUCH longer line than the gen 1 JKs. Aftermarket longer front brake lines/VSS wire extensionss arent needed with a 3" lift if you remove the bracket and route the lines "normally".
The exhaust that everyone is so worried about - the trumpet doesnt hang THAT low, but I'd definitely put a skid over it. Waiting to hear back from JCR on why we had to cut 3" off their skid to clear the DS.
Teraflex's spacers take care of the driveshaft/crossover pipe interference issue - simple solution that works.
You no longer have to cut the bolt to remove the passenger side upper arm!
Evap can now has a factory "skid" over it - well, i f you call being wrapped in metal only slightly thicker than a beer can a skid.
Passenger side upper shock bolt SUCKS! The bottom of the fuse box sits right on it and getting to the nut on top is almost impossible. Especially getting the nut on top of a fox shock started. You can "clearance" some of the hard plastic out of the way to give yourself some finger room to get the nut started and its a little easier.
New steering stabilizer clamp on the tie rod is a pain to remove to install a poly/fox setup. The old double u-bolt deal on the first gen JK tire rods has been replaced by a metal wrap around deal - cutoff wheel is your friend to remove it, its actually pretty thick metal and straightening it enough to get it off the rod is pretty hard because theres no good way to pry it open that far.
otherwise things are pretty much the same as working on the suspension of a first gen.
The vacuum booster pump is in a stupid spot on the frame rail and interferes with most recessed winch bumpers, but is relocatable.
And poly's stage 3 kit is STILL amazing!
If I remember anything else- I'll add it.
