0-3" #1753710 $559.99
4-6" #1753715 $559.99
The TeraFlex S/T Swaybar System is one of the most advanced swaybar disconnect systems available. With its easy engagement knob you can go from street to trail in seconds - literally! The S/T Swaybar System, when engaged, provides a stable highway drive. Disconnected, it allows your vehicle to articulate and your tires to bite despite the terrain. Unlike conventional swaybar disconnects, the S/T bar does not require you to pull, pry and tug on removable links. To disengage the swaybar with the S/T system, simply twist a knob and you are on your way. To re-engage, rotate the knob again and the swaybar will self engage when the vehicle is level. Fits all JK Wrangler models including the Rubicon.
Dual Rates will be available in few weeks.
So does this 'disconnect' completely? Or is there still some influence from the bar when unlocked?
Any pictures of it installed and flexing?
