Do you still need to relocate your evaporator coil with this kit or is that covered as well?
Not sure what you mean by evaporator coil, could you clarify? (evaporator canister maybe?)
Which lift do you have installed? Haven't ordered my shafts yet... How do uou like the JEReel? I've got the Evo Protek and Teraflex spacers to put on and trying to figure my other issues.
I've only got about 20 miles on the Reel, but so far, no vibration and no problems. I went with replacement yokes so the shaft angle would be a little less than a shaft with adaptor plates.
I've got a Synergy 3" lift with control arms, but drive shaft contact with the cross over pipe has more to do with extended shock length and less to do with lift height. I believe the factory shaft is safe as long as the new shocks are maximum 2" longer than the factory shocks. Any longer and the axle will droop far enough to allow the plastic boot to make contact with the exhaust pipe. My Bilstein shocks are 27.56" extended so keep that in mind when I post my results.
And as mentioned above, you'll probably still have rattling issues with the spacers, but since you already have them, it doesn't hurt to try. I've seen several people say they had issues with spacers, but I've also seen one post that said they were rattle free.
