Tailgate Holder Popped Out
1 reading
5.6K views 5 replies 4 participants last post by  ronjenx
#1 ·
This bloody thing popped out of the tailgate holder ensemble and won't get back in.
How do I persuade it to obey?
#3 ·
i love having this now. although if you're retro fitting it, i would go with the woods kit. had it on my 09 for 2 years and it never failed me (unlike the above). it might seem pricey for just a piston and some brackets, but it's worth every penny.
#5 ·
Yes, I did fix it.
All you need to do is pull the arm back through the rollers (in reverse of how it came out).
For that I drilled a small hole through the rear tip (not the one with the joint) between the tip and the shoulder. The plastic coating sports some round mold marks there and I drilled through them (in the picture the white spot on the tip).
Then I attached some thin braided-steel wire through the hole and routed it through the rollers. Grip the wire end however you can. Use pliers or wrap it around a handle or whatever you can think of.
Then I fastened the roller housing in a vise and pulled the arm through.
My previous attempts to push the arm back-in increased the curvature of the arm so I straightened it a bit with a rubber mallet.
Hope this helps. Sorry I didn't take any pictures.
Legi0n
