1 - 1 of 1 Posts
Part Number 8007 $35 plus shipping.
Relocates the JK steering stabilizer as long as it is 1-3/8" mounting width with a 1/2" bolt. Complete kit to relocate the steering stabilizer. Comes with high-quality grade 8 hardware made from durable powder coated 3/16" steel. Also has the stabilizer bolt and nut.
The kit is designed to be used with or without the Synergy Front Track Bar Bracket (8055). Please note that 2011 and newer Jeeps will require the use of a 8003 Tie Rod Clamp since the factory clamp is unable to be flipped. Flipping the tie rod clamp will interfere with the differential cover.
Nothing wrong with this just went with a different setup.
1 - 1 of 1 Posts
